KKmoon sd27w IP Camera: P2P Connection Instability on Android Devices
hkmfly 5196 2
  • #1 16412036
    hkmfly
    Hello, the KKmoon sd27w IP camera, works in the local network via wifi, when trying to connect with the P2P application on Android, the status in a fraction of a second changes from online to connected and it jumps over and over again like crazy. I've tried with different apps and devices and it's still the same. So I exclude hardware, applications and the network. Everything on the PC is working properly is controls and
    picture via wifi. You cannot only "enter" the camera with your smartphone. I am asking for help as I can check as a layman.
    michualex
    Help: 82
    Rate: 134
    use the application dedicated to the camera. There will be a problem with other apps.
    MK ALARMY
    Widziszewo, Długa 3, Kościan, 64-000 | Tel.: 663XXXXXX (Show) | Company Website: www.mkalarmy.pl
  • #3 16412827
    hkmfly
    Thank you, it helped. The proper application is CamHI. I have 4 cameras, each from a different manufacturer, 2 use one application, 2 others. Too bad it's not unified, now I know the app matters. It's not very convenient.
