Briggs & Stratton - No wire fixing the speed controller spring.
Piotrekcy 32469 5
  • #1 16452133
    Piotrekcy
    Rate: 8
    I have a problem because I do not have this wrapped rod to which the springs from the speed controller are attached. I can not get him anywhere. All carburetor repair kits contain these springs, but nowhere is this rod. Can someone tell me where I can get it?
  • #3 16452327
    Piotrekcy
    Rate: 8
    I could not find it because I did not know how to call it properly. On Allegro, from what I see, it is to Tecumsen and Honda.
    From such is only the one you submitted, because I also found to Briggs & Stratton, but they have a different shape.
  • #4 16452390
    Romulus7874
    Help: 109
    Rate: 459
    Do you have any tools? That's something in a minute (with amendments) you will do. Dimension you?
  • #5 16452413
    Piotrekcy
    Rate: 8
    Romulus7874 wrote:
    Dimension you?
    could
    I just think to do it yourself, because pay 40 PLN (including shipping) for such a pierz is a slight inflection.
  • #6 16452524
    Romulus7874
    Help: 109
    Rate: 459
    The wire is 1.7mm (it has to move loosely in the holes). What I did not measure is the proportion of do it. Briggs & Stratton - No wire fixing the speed controller spring.
