System Migration to SSD: Cloning Win.8 from GPT to MBR Using Good Ram SSD & EaseUS Todo Backup Free
okobogee 6306 14
Jak sklonować Windows 8 z dysku GPT na SSD, gdy EaseUS Todo Backup Free blokuje migrację z powodu różnicy GPT/MBR?
Najprościej przekonwertować SSD na ten sam styl partycji co system, czyli na GPT, a potem ponownie wykonać migrację [#16453124] W wątku padła też rada, że taką konwersję/formatowanie można zrobić w Diskpart albo w Zarządzaniu dyskami Windows i nie powinno to uszkodzić dysku SSD [#16453124][#16455545] Autor wątku potwierdził, że problem rozwiązał właśnie przez Zarządzanie dyskami w Windows i potem wykonał migrację według instrukcji z YouTube [#16455545]
  • #1 16452945
    okobogee
    I warmly welcome,
    I am asking for tips on how to solve my problem.
    I bought a Good Ram SSD and wanted to clone Win.8
    For this purpose, I installed the EaseUS Todo Backup Free program and followed the guidelines I found on YouTube.
    At the end I received a message that I can not migrate the system because the system is some GPT and the SSD drive is MBR.
    Ladies and gentlemen, I can not clone this program unless I buy an extended version for 44baks.
    I am asking for tips on how to deal with this problem.
    Has anyone encountered a similar problem?
  • #2 16453124
    Broda83
    Rate: 18
    You can get a little bit tired of migrating the system from the GPT to MBR standard. It's easier to format an SSD disk on GPT using a program such as Diskpart
  • #4 16453286
    okobogee
    I have a question if formatting this disk on GPT will not hurt?
    Well, how to stretch this disc cheap was not and I did not want to damage it or shorten its life.
    I was a bit disappointed with the goodram company: / It has good reviews but I did not expect such a problem .. maybe my fault is that I did not ask the seller what type of disk, but the software for such a migration should be.
  • #5 16453324
    iron64
    Help: 648
    Rate: 313
    And what does the SSD disk manufacturer have for the sibling partition? You set the partition type yourself, and is Goodram to blame? Weird. You also have not bought the software and you think it should be, why?
    GPT does not bother you at all, did you read the link above?
  • #6 16453388
    atomic99
    Help: 171
    Rate: 338
    @okobogee
    okobogee wrote:
    I have a question if formatting this disk on GPT will not hurt? Well, how to stretch this disc cheap was not and I did not want to damage it or shorten its life.
    What is supposed to harm formatting?
    What are you saying nonsense, what kind of software would the producers add to the disks. Perhaps the best disc with the operating system, no disc manufacturer does not add software to the disk.
    As you started to "combine like a horse uphill", it's no wonder that you motivate and tire.
    There was a copy of the files and programs from the old disk, plug in the new SSD, install the system from the DVD and everything.
  • #7 16453434
    okobogee
    atomic99 wrote:
    @okobogee
    Well ok, I understand that I harm myself: /
    Well, I do not have a system on the board, I have a recovery disc which I did as a computer for the first time I launched. Now this recovery tile tells you that the disk is too small: /
    Gentlemen, does it somehow fix it formatting this ssd drive from the windows position
  • #8 16453459
    atomic99
    Help: 171
    Rate: 338
    @okobogee Did you update to Win10?
  • #9 16453470
    okobogee
    I did not do 8.1
  • #10 16453483
    atomic99
    Help: 171
    Rate: 338
    Then make yourself copies of the necessary files, do it update to Win10 , copy the license files and Win10 serial number.
    Mount the SSD, download the Win10 image and install it freshly (do not enter the key during installation), then copy the license files and you have the Win10 system activated.
  • #11 16453504
    okobogee
    And I thought that no longer a free upgrade is not possible: 0
    I have a question about how to copy license files, where are they?
    Thanks to Atomic99
  • #12 16453529
    atomic99
    Help: 171
    Rate: 338
    Enter on google, "copy Win10 license files".
  • #13 16453671
    Piotr160292
    Help: 374
    Rate: 282
    It is, but provided you have Windows 8, or 7 ...
    A copy of the license is unnecessary. You simply install the system without a key and wsio. The system autmatically activates, and if it does not happen then you call Microsoft technical support, you say that you have made an update to Windows 10 and the system does not want to activate and the consultant with whom you will be connected will take care of the rest. Really, very friendly and helpful people work there. They will not bite when you call the problem. I have often contacted them with various problems, and no employee with whom I was connected ever left me on the ice and even encouraged me to contact them again if their advice did not help.
  • #14 16453677
    atomic99
    Help: 171
    Rate: 338
    @ Piotr160292 Why did you write it? Since the author of the topic even in # 1 wrote that he has Win8. And whether it is Win8 or Win8.1, it does not matter.
  • #15 16455545
    okobogee
    Hello, gentlemen, ladies, the problem has been solved.
    It turned out that the best way would be to format the SSD drive from the Windows panel, select> disk management> then the mouse pointer moves to the given partition where the icon and right click, choose convert to MBR on GPT
    And I made the migration according to the instructions on YouTube, which is presented by ForumWiedzy.pl
    Thank you all for participating in helping me solve the problem.
    The topic can be closed.
The discussion revolves around the challenges faced when migrating a Windows 8 system from a GPT partition style to an MBR partition style on a Good Ram SSD using EaseUS Todo Backup Free. The user encountered an error indicating that the system could not be cloned due to the differing partition styles. Various suggestions were provided, including formatting the SSD to GPT using Diskpart, understanding partition styles, and performing a fresh installation of Windows 10 after backing up necessary files. Ultimately, the user resolved the issue by formatting the SSD through Windows Disk Management and successfully migrating the system following online instructions.
