Lenovo 100s-14IBR - Transfer of the system from eMMC32GB to SSD m.2 128GB
11757 4
  • #1 16435293
  • #2 16435308
    sylweksylwina
    Help: 1882
    Rate: 2355
    Cloning the partition will run like on other media so I do not know what the problem for a person with extensive experience. Recovery should also be moved.
    It is not known whether the laptop will start up from m2, someone would have to confirm it, nor is it known whether Recovery will start from the m2 disk.
    You can use for this treatment, for example Clonezilla.
  • #3 16435334
  • #4 16435367
    lisek
    Service technician RTV
    Help: 6352
    Rate: 6883
    Rónie mówiá Różnie mówią o.. różnych laptopach z taka migracją.
    Spróbuj porady na jednym z for o Win10
    You would have been better
    -off imaging the OS, including partitions, from the SSD, then restoring the image to the M.2 drive.
    Boot and format the original SSD drive prior to image restoration.
    Make certain that the M.2 drive is installed and shows up in BIOS and as an image restoration option when you go to
    boot to the restoration disk with the imaging application of your choice.
    (preferably a 3rd party option and NOT MS's Backup & Restore)
    Oraz wnikliwie to z forum (communities.intel.com) Link
  • #5 16444383
