Windows 10 Home Update Errors After SSD Disk Swap and EaseUS Todo Backup Clone
Dawiidos 4740 3
  • #1 16956964
    Dawiidos
    I switched to a ssd disk in my laptop - a clone made with EaseUS Todo Backup. After replacing the disks, I made Windows Update (Windows 10 Home). Error 0x80080005 appeared. Trying again does nothing.
    After links etc. I got to the command line where I did such steps
    1.Dism / Online / Cleanup-Image / ScanHealth -> The operation completed successfully.
    2.Dism / Online / Cleanup-Image / CheckHealth -> The component store is repairable. The operation completed successfully.
    3.Dism / Online / Cleanup-Image / RestoreHealth / Source: F: \ sources \ sxs / LimitAccess -> appears Error: 0x800f081f Use the "Source" option to specify the location of the files that are required to restore the feature
    4.Dism / Online / Cleanup-Image / RestoreHealth / Source: F: \ sources \ sxs -> Error: 0x800f0906 The source files could not be downloaded.
    Use the "source" option to specify the location of the files that are required to restore the feature.
    I also tried to get to Local group policy editor (gpeditor.msc), but it did not find startup after typing in the search engine. I tried to move 2 folders from syswow64 to system32 regarding group policy. It turned out that they were empty, and gpeditora.msc was different in this location.
    MMC cannot open the file: /
    Does anyone have an idea how to solve this problem effectively?
  • #2 16976404
    piotr147
    Help: 12
    This is not always successful.
    At least how is the difference in disk capacity.
    it's best to reinstall everything.
  • #3 16976468
    RADU23
    Help: 2428
    Rate: 1732
    If you still have an old HDD drive and the untouched data on it that you want to transfer to a new SSD, the best solution would be to make a post-sectoral copy, which will reflect all the 1: 1 data.
    The condition is that the target disk must be equal (or larger) capacity from the disk from which the data will be ripped.
    https://www.elektroda.pl/rtvforum/topic1330869.html
  • #4 16977330
    safbot1st
    Help: 2719
    Rate: 1585
    Dawiidos wrote:
    using EaseUS Todo Backup.
    Unfortunately, such programs effectively damage the structure of new "untouchable" systems above W7 (especially by doing the unimaginable - cloning from the level of OS, which is cloned).
    Check clonezilla. The condition has already been given - the destination disk is the same or larger than the source disk.
    ps. Recently I was rolling out a topic where the system did not fire with SSD even after successful cloning 1: 1 with HDD. Before we were blamed for bio-current and magic, there was a hypothesis for OS access to the HDD service zone; ?.
