Kiano x1 FULLHD Windows 10 Creators Update - Seeking Working Touchscreen Drivers and Solutions
cisnia 5613 2
  • Request for a full driver backup including touch support
    #1 16482697
    cisnia
    I'm looking for drivers where everything will work, including touch.
    Kiano x1 FULLHD
    Windows 10 creators update
    The best solution would be to reply to the manufacturer's message, but unfortunately this does not happen: /
    I installed clean windows 10 creators update, clean with msdn, found some drivers, but most of them have problems (e.g. battery, screen, touch).
    It would be good if someone who has this tablet with windows untouched, made a backup of the current drivers (e.g. double driver).
    Regards and waiting for a quick reply.
  • Administrator-run TP touch driver batch fixes inversion
    #3 16483262
    cisnia
    Thanks for the answer :) It was from this package that I tried to install the drivers and unfortunately the touch is still inoperable: / any other ideas?
    Added after 2 [hours] 6 [minutes]:
    My problem is exactly that the touch is inverted, did someone find a solution?
    I have already checked the drivers from another kiano tablet - nothing helped.
    Added after 2 [hours] 1 [minutes]:
    I already know the solution - banal.
    The .bat file in the package with the TP touch driver, you just need to run as administrator :) I greet everyone. Certainly someone will need it
