[Solved] Kiano SlimNote 10.1: Need Windows 10 32bit Drivers (Graphics, Sound, Card Reader, Battery)
toldi11 13275 9
Where can I download Windows 10 32-bit drivers for the Kiano SlimNote 10.1, including graphics, sound, card reader, and battery drivers?
The manufacturer provided a driver package for the Kiano SlimNote 10.1; download it from https://we.tl/3qODTfsBu1 [#17162093] The poster said they received it after a week of dealing with the Kiano hotline and considered the issue closed [#17162093]
  • #1 17144746
    toldi11
    Rate: 11
    Would anyone have drivers for this system? Or at least knows where to download them for Windows 10 32bit (graphics, sound, card reader, battery etc.).
    Any help is much appreciated.
  • #2 17144851
    Kolobos
    IT specialist
    Help: 17167
    Rate: 10448
    Provide device identifiers for which drivers are missing (pid and vid as well as ven and dev) from the device manager.
  • #3 17145030
    toldi11
    Rate: 11
    I was able to install most after throwing platform drivers into the intel Z3000 series processor but the sound is no further.
    In details, I have the following:
    ACPI \ VEN_8086 & DEV_0F28 & SUBSYS_80867270
    ACPI \ 80860F28
    * 80860F28
    and displays as unknown device. I will add that Windows update finds the driver but displays information that it is not on this platform.
  • #4 17145043
    Kolobos
    IT specialist
    Help: 17167
    Rate: 10448
    Those with WU should match: http://www.catalog.update.microsoft.com/Scope...updateid=3130ece3-7539-4e59-b3c2-88c6da438f2f
    If not these: https://drp.su/en/devices/sound/intel/intel-sst-audio-device-wdm?os=windows-10-x86 download, download the downloaded exe file with 7zip and install manually from the device manager level. Do not run downloaded exe files.
  • #5 17145081
    toldi11
    Rate: 11
    Unfortunately, the first link does not work, i.e. there is information that the website has encountered an error, and after the installation from the second link the device disappeared and then after the computer restarted but with the error code 10.
    I will add that in the control panel in the sound section there are no default devices except steam bt.
  • #6 17145139
    Kolobos
    IT specialist
    Help: 17167
    Rate: 10448
    "No," don't write together, remember it and don't make that mistake again!
    No wonder, since it's still not installed correctly.
    There are two driver versions on the drp website, did you check both?
  • #7 17145170
    toldi11
    Rate: 11
    So I downloaded both versions below:
    Intel (R) Atom (TM) / Celeron (R) / Pentium (R) Processor Low Power Engine Audio - Host Bridge - 0F2810.1.1.18 (04/04/2016)
    Intel SST Audio Device (WDM) 604.10135.2747.11324 (Jan 12, 2016)
    But only in the second version are the audio drivers
  • #9 17162093
    toldi11
    Rate: 11
    After a week of fighting the kiano hotline, I received drivers for this invention, below is a link to Kiano SlimNote 10.1 drivers for those in need
    [url=]https://we.tl/3qODTfsBu1 [/url]
    I consider the topic closed
  • #10 17162098
    toldi11
    Rate: 11
    Drivers above
✨ The discussion revolves around the search for Windows 10 32-bit drivers for the Kiano SlimNote 10.1, specifically for graphics, sound, card reader, and battery functionalities. Users are advised to provide device identifiers (PID, VID, VEN, DEV) to assist in locating the correct drivers. Some users report partial success in installing drivers, particularly for the Intel Z3000 series processor, but encounter issues with sound drivers, including error codes. Links to driver resources are shared, but some are found to be non-functional. Ultimately, a user shares a link to the drivers obtained from Kiano's support after persistent efforts, concluding the discussion.
