Seeking Kiano Intelect X3 HD Touch Screen Drivers (ACPI/VEN MSSL & DEV_1380)
maksior8 12951 5
  • #1 16523188
    maksior8
    Hello, I need drivers for kiano intelect x3 hd and specifically for the touch screen (acpi / ven mssl & dev_1380), maybe someone has such a tablet and could rip drivers or make copies of the elevator with all the software.
    Greetings.
  • #2 16671931
    burtix12
    I have exactly the same problem
  • #3 16672578
    gradek83
    Help: 930
    Rate: 2103
    Have you checked these drivers?
    • AMD VEN_ASD&DEV_0001.zip (61.43 KB) You must be logged in to download this attachment.
  • #4 16726230
    Dj Darecki
    Help: 5
    Rate: 9
    And ? people, write whether it worked or not
  • #5 16738820
    robs001b
    Rate: 13
    That driver does not work.
    Link with drivers from technical support attached
    Working
    • Link.txt (77 Bytes) You must be logged in to download this attachment.
  • #6 16794956
    Dj Darecki
    Help: 5
    Rate: 9
    Okay, I put the system back and, surprisingly, no drivers were needed.
    Works as it should.
