Affordable Dual-Band Router for Home Use with 2.4GHz, 5GHz, N/AC Standard & 150Mbps Support
jacekmi91 4110 13
What inexpensive dual-band home router with 2.4 GHz and 5 GHz, 802.11n/ac support, and reliable handling of up to 150 Mbps should I buy within about PLN 150–200?
If your budget is around PLN 200, the recommended choice is the ASUS RT-AC53; if you can stretch to about PLN 300, the ASUS RT-AC1200G+ is the smarter buy because it is faster and adds USB 2.0 for NAS or a 3G/4G LTE modem [#16459279][#16459368][#16459515] If you want to stay below PLN 150, the alternatives mentioned are the Netis WF2780 and TP-Link Archer C25, but ASUS is still suggested as the safer brand choice [#16459328] The RT-AC53 is specifically preferred over the lower ASUS RT-AC51, and it is presented as better than the cheaper Netis and TP-Link models [#16459368]
  • #1 16459173
    jacekmi91
    Hello, I would like to ask about a good and cheap router for home use.
    Basic required features:
    - simultaneous dual band (DualBand) 2.4 GHz and 5 GHz
    - good signal quality near and far router (I do not know if it is possible)
    - operational reliability (failure to hang up, overheating, 24/7 operation)
    - trouble-free internet support up to 150 Mbps download
    - minimum support for the N standard, with the ability to support the AC standard
  • #2 16459257
    AxelNext
    Help: 265
    Rate: 454
    You're restricting yourself to 150 Mbps :?: For what :crazyeyes:
    Up to what the maximum price should this router be :?:
  • #3 16459268
    jacekmi91
    I limit the speed because of the price, because I do not need more, because I currently have a 100/10 Mbps connection. As for the price, I would not like to pay more than PLN 200. But I'm not sure if it is possible: /
  • #4 16459279
    AxelNext
    Help: 265
    Rate: 454
    Up to PLN 200. you will buy ASUS RT-AC53, unless you need USB.
    With USB up to PLN 300. you will buy ASUS RT-AC1200G +
  • #5 16459296
    jacekmi91
    It's just a pity that there is no recki for the former. And something up to PLN 150 would be found?
  • #6 16459328
    AxelNext
    Help: 265
    Rate: 454
    Asus routers are a proven brand and can be taken blindly.
    Up to PLN 150. you can buy Netis WF2780 or TP-Link Archer C25 however, I would suggest buying Asus.
  • #7 16459334
    jacekmi91
    Seemingly a proven brand, but when you look at the tests of these cheaper versions, it loses the signal quality with Netis or TP-Link.
  • #8 16459368
    AxelNext
    Help: 265
    Rate: 454
    I offer you a good ASUS RT-AC53, not the lower-end ASUS RT-AC51
    ASUS RT-AC53 is definitely better than Netis WF2780 or TP-Link Archer C25
    My proposal is ASUS RT-AC53, and you will do and buy whatever you want, but then you will not regret it because now you have a 100Mb / s net, and in a year or two you will have 200 or 250 Mb / s and then you will replace the router again :?:
    I have ASUS RT-AC68U and 250Mb / s for a few days, and for almost 2 years I had 120Mb / s, previously 60Mb / s.
    I changed the net to a faster one because I wanted to :?: No, because my contract has expired and they offered me 120 Mb / s for PLN 4. less, or 250Mb / s for PLN 2. more.
    and what I chose :D
    After WiFi, I reach over 220Mb / s :idea:
  • #9 16459407
    jacekmi91
    and what I chose :D
    Tell me again, are you reaching the 220 in a different room than the router is?
  • #10 16459424
    AxelNext
    Help: 265
    Rate: 454
    In the same room:
    speedtest.net/pl
    5 GHz AC 226 Mb / s (fix)
    5 GHz N 145 Mb / s
  • #11 16459428
    jacekmi91
    AxelNext wrote:
    In the same room:
    speedtest.net/pl
    5 GHz AC 222Mb / s
    5 GHz N 145Mb / s
    can you do a test and check in another room?
  • #12 16459442
    AxelNext
    Help: 265
    Rate: 454
    In the second room behind a 30 cm brick wall:
    speedtest.net/pl
    5 GHz AC 221 Mb / s
    5 GHz N 137 Mb / s
  • #13 16459474
    jacekmi91
    speedtest.net/pl
    5 GHz AC 221 Mb / s
    5 GHz N 137 Mb / s
    pretty good results
  • #14 16459515
    AxelNext
    Help: 265
    Rate: 454
    Therefore, I advise you not to save on the router.
    I proposed ASUS RT-AC53, but a smarter purchase is ASUS RT-AC1200G + because not only is faster, it also has USB 2.0 to which you can connect a hard drive in the housing and use it as a NAS, or watch movies on TV if you have a TV with an Internet connection or in connect the 3G / 4G LTE modem if necessary and use the mobile network. This router gives you more options.
    I know that PLN 300. it's not enough but if you have 200 then wait, collect the 100 more and you will certainly be more satisfied.
The discussion revolves around finding an affordable dual-band router suitable for home use, specifically one that supports both 2.4 GHz and 5 GHz frequencies, with a maximum download speed of 150 Mbps and compatibility with N and AC standards. Users suggest several models within a budget of PLN 200 to PLN 300. The ASUS RT-AC53 is frequently recommended for its reliability and performance, while alternatives like the Netis WF2780 and TP-Link Archer C25 are also mentioned. Concerns about signal quality and operational reliability are raised, with users sharing personal experiences regarding speed tests in different rooms. The ASUS RT-AC1200G+ is suggested as a more versatile option due to its additional features, including USB support for NAS functionality.
