Best AC Routers under PLN 350: ASRock GAMING AC2600 G10, 2.4 GHz/5 GHz, Beamforming, OpenWRT
datexxxxxx 5685 13
Is the ASRock GAMING AC2600 G10 a good router under PLN 350 for dual-band Wi‑Fi, beamforming, gigabit ports, and possible OpenWrt support?
The ASRock G10 is probably the best hardware choice in this price range: it is based on an 11ac Wave 2 QCA9980 platform with 4x4 MU-MIMO, beamforming, 512 MB RAM, and gigabit ports, and one reply calls it unrivaled in this class [#17516504] [#17518767] However, it does not have a ready OpenWrt build; the alternative firmware mentioned for it is DD-WRT [#17518767] If OpenWrt is the priority, the ASUS RT-AC58U is the more software-friendly option, but it only offers 2x2 MU-MIMO and 128 MB RAM, while the ZyXEL NBG6617 has the same chipset but no ready OpenWrt distribution [#17527485] For an attic installation with two ceilings to cover, replies also warn that one router may still not provide good whole-house coverage and suggest using separate APs per floor instead [#17517872] [#17527656]
  • Clarifying router requirements and asking about ASRock G10
    #1 17516339
    datexxxxxx
    Hello, I am asking for advice on choosing a router.
    - the price is about PLN 350,
    - support for 2.4 GHz and 5 GHz networks,
    - beamforming (the router will be placed in the attic),
    - gigabit ports (internet connection is 200Mib),
    - at least 2-core processor so that there are no problems with performance,
    - the possibility of changing the software to alternative ones (e.g. OpenWRT) is welcome.
    Is it worth being interested in the ASRock GAMING AC2600 G10 (G10 / RT / WOH / B) router?
  • 4x4 ac routers with MU-MIMO and OpenWrt caveats
    #2 17516504
    Nagus
    Help: 99
    Rate: 97
    Look for routers advertised as supporting MU-MIMO. Only the second generation 11ac chipsets support MU-MIMO and beamforming. The fact that it was standard is irrelevant.
    The cheapest potential option, TP-Link Archer C6, is not yet available in stores. The higher model (3x3), the Archer C2300, is already PLN 500-600.
    The best results will be achieved by something 4x4, eg Netgear R7800, but here you have to play PLN 800-900. Asus and ZyXEL models are similar in a similar price range.
    This Asrock is quite an interesting option, because for less than 4 cents we have an ac 4x4 router. But it's made on the older QCA9980 chipset, and I'm not sure this one already supports beamforming. The mentioned Netgear 7800 is on the newer QCA9984.
    As for OpenWrt and derivatives, you need to find a model and look for an alternative soft to it.
    For around PLN 300, only Xiaomi R3P can be pulled out. The problem is that the original soft has quite modest possibilities and is only in Chinese (although the Anroid app can be configured in English). An alternative soft (Pandorabox) is available for Xiaomi.
    Of the cheaper ones, there is also the D-Link DIR-882, but this one has little memory, so if something more happens on the network, it can become clogged. And support for Mediatek in OpenWrt is rather modest.
  • ASRock G10 specs and range concerns
    #3 17516951
    datexxxxxx
    Thank you for your answer.
    The Archer C2300 or R7800 are interesting proposals, but well beyond the budget.
    Xiaomi R3P - here is the problem with availability and a possible warranty.
    I am currently wondering about the ASRock GAMING AC2600 G10, which seems to have a good setup for this price range:
    CPU IPQ8064
    256MB flash
    512 MB RAM DDR3
    2.4G QCA9980
    5G QCA9980
    Switch QCA8337
    The disadvantage of this router are the squeaks coming from its inside during a greater load (audible up to 1.5m), or at least this information was found. I do not know if this applies to all copies, but in the case of modernization in the attic, it will not be a bigger problem.
    The only concern is the range, there would be 2 ceilings to cover. I currently have a TPLink Archer C1200 v1.0 router, it would be nice if the range was at least the same.
  • #4 17517050
    lukaszd82
    Help: 143
    Rate: 491
    I will add Tenda ac10 from myself
    It is a simple Router for about PLN 180 to buy in PL.
    Read on, for this price it is unbeatable (of course, if we accept its drawbacks and limitations.
    It has MU-MIMO and Beamforming.
    Link
    Link
  • Attic placement will severely limit Wi‑Fi range
    #5 17517872
    KOCUREK1970
    Help: 3863
    Rate: 5493
    Then forget that you can use wifi throughout your home.
    Modern routers are even more stringent in terms of wifi radiation - the power of the wifi radio for 2.4 GHz is only 100mW and for 5 GHz it is 200mW (this is the law).
  • #6 17518767
    Nagus
    Help: 99
    Rate: 97
    However, it turns out that the older one QCA9980 is already an 11ac wave 2 chipset. So the mentioned Asrock is unrivaled. And there's dd-wrt underneath it.
    Beamforming is more effective the more antennas there are, so pushing in 4x4 is justified.
  • #7 17525472
    datexxxxxx
    thank you for any suggestions. Below is a summary of the different models:
    Tenda ac10
    - 11ac wave 2
    - beamforming
    - MU MIMO 2x2, range and performance definitely better than TP-Link AC1200 (no 11 ac wave 2),
    - no OpenWRT (due to the Realtek chip)
    - probably the cheapest device compatible with 11 ac wave 2
    - original firmware underdeveloped
    - no USB
    - gigabit ports (3 lan + 1 wan)
    Asrock G10
    - 11ac wave 2
    - beamforming
    - MU MIMO 4x4
    - only DD-WRT support, no OpenWRT (The use of Qualcomm chips does not preclude the possibility of adding OpenWRT support). The reviews show that OpenWRT is definitely better
    - 512MB ram
    - probably the best components up to PLN 400 - the main advantage
    - gigabit ports (4 lan + 1 wan)
    ASUS RT-AC58U
    - 11ac wave 2
    - beamforming
    - MU MIMO 2x2
    - IPQ4018 SoC . 4 core processor
    - powered by OpenWRT
    TP-Link Archer C7 v5
    - 11ac wave 2
    - beamforming
    - MU MIMO 3x3
    Must have for me are: 11ac wave 2, gigabit ports, alternative software (preferably OpenWRT, however DD-WRT can also be). The questions that arose while looking for the router were:
    1. 512MB RAM - is this amount of memory really needed?
    2. Does the 4-core processor really give you anything? If so, ASUS RT-AC58U also seems to be an interesting proposition, due to the fact that I do not need Acer goodies (H2R, infrared ports)
    3. Is MU MIMO 4x4 definitely better than 2x2?
    regarding the 3rd point:
    article about whether we need 4x4 MU MIMO - in short, 2x2 is more than enough. 4x4 also requires a device that supports 4x4 MU MIMO. Due to the use of more antennas, beamforming should perform better for all ac compatible devices, but don't expect too much.
  • #8 17525609
    KOCUREK1970
    Help: 3863
    Rate: 5493
    No (at the moment) - but each software is developmental, so it needs more and more memory to work.
    datexxxxxx wrote:
    does the 4-core processor really give you something?
    It allows for greater traffic routing, faster NAT, faster packet processing, lower power consumption due to multi-threading of the processor.
    datexxxxxx wrote:
    is MU MIMO 4x4 definitely better than 2x2?
    If the network cards in the devices do not support it, then even MU MIMO 16x16 will not help!
    Please remember that the specificity of routers are closed devices (you can do exroot to enlarge the ROM - but there are always problems with that later).
  • #9 17525971
    makosuu
    Help: 369
    Rate: 370
    Flash can be replaced, sometimes USB can be added etc. But you have to know how.
  • #10 17527074
    datexxxxxx
    At the moment, the favorite is ASUS RT-AC58U, due to the 4 core processor, 128MB of RAM, OpenWRT, 11 ac wave 2, the price is about 365 PLN. Is there a router with similar capabilities at this price than mentioned in the previous comment? As for the processor, it can also be 2-core.
  • #11 17527485
    Nagus
    Help: 99
    Rate: 97
    The ZyXEL NBG6617 has the same chipset as the Asus AC58U and 256M RAM, but does not have an OpenWrt distribution ready.
    From the budget ones, there are also devices such as D-Link DIR-882 (4x4, approx. 440 PLN), but the OpenWrt support for Mediatek is weak.
    How much RAM is needed depends on what will start on the router, means how many clients, how many features ... 128M on 2x2 hardware is rather enough. But with larger ones, you'll melt the torrent, fire up QoS controls, some DLNA, a few more clients, and 128M can get clogged.
  • #13 17527583
    lukaszd82
    Help: 143
    Rate: 491
    internick wrote:
    datexxxxxx wrote:
    Tenda ac10
    Asrock G10
    ASUS RT-AC58U
    Of these models, only AsRock G10 and Asus AC58 have Mu-Mimo:
    https://wikidevi.com/wiki/Tenda_AC10
    https://wikidevi.com/wiki/ASRock_G10
    https://wikidevi.com/wiki/ASUS_RT-AC58U
    https://wikidevi.com/wiki/TP-LINK_Archer_C7_v5.x
    So the manufacturer on the main page is lying?
    Tenda AC10
    Wiki is not the best source in this case ...
    You have to check what is actually installed in the router (what chip) and everything would be clear. You can probably find this data on the web.
  • #14 17527656
The discussion revolves around selecting a router under PLN 350 that supports dual-band (2.4 GHz and 5 GHz), beamforming, gigabit ports, and has a multi-core processor, with a preference for models compatible with alternative firmware like OpenWRT. The ASRock GAMING AC2600 G10 is highlighted as a potential option due to its specifications, including a dual-core IPQ8064 processor, 512 MB RAM, and support for MU-MIMO and beamforming. However, concerns about its chipset (QCA9980) and potential noise during high load are noted. Other models discussed include the Tenda AC10, ASUS RT-AC58U, and TP-Link Archer C7, with varying support for features like MU-MIMO and OpenWRT. The ASUS RT-AC58U emerges as a strong contender due to its 4-core processor and compatibility with OpenWRT, while the ZyXEL NBG6617 and D-Link DIR-882 are mentioned as alternatives with different specifications and support levels.
TL;DR: For budget AC buyers, 4x4 streams help, and “Beamforming is more effective the more antennas there are.” ASRock G10’s QCA9980 is 11ac Wave 2 with DD‑WRT, making it a standout value pick. [Elektroda, Nagus, post #17518767]
Why it matters: This FAQ helps you choose dual‑band MU‑MIMO routers with upgradeable firmware without overspending.
Is the ASRock GAMING AC2600 G10 a smart buy in this budget?
Yes. It runs the Qualcomm QCA9980 (11ac Wave 2) with 4x4 Wi‑Fi and DD‑WRT. That combination yields strong throughput and better beamforming potential. A forum expert even called the G10 “unrivaled.” Consider it if you want MU‑MIMO with upgradeable firmware. [Elektroda, Nagus, post #17518767]
Will attic placement cover two floors through ceilings?
Do not rely on it. Legal RF limits cap 2.4 GHz at 100 mW and 5 GHz at 200 mW. Those limits and two ceilings make whole‑home coverage unreliable from an attic. Expect dead zones and weaker speeds across floors. [Elektroda, KOCUREK1970, post #17517872]
How much RAM do I need in a home AC router?
It depends on features and clients. On 2x2 hardware, 128 MB is usually sufficient. Heavy usage can change that. Enable torrents, QoS, DLNA, and add more clients, and 128 MB can get clogged. For such workloads, favor more memory. [Elektroda, Nagus, post #17527485]
Does a 4‑core router CPU actually help performance?
Yes. More cores increase routing capacity and accelerate NAT and packet processing. Multithreading also lowers power with the same workload. You will feel the difference under load or with many clients. [Elektroda, KOCUREK1970, post #17525609]
Is 4x4 MU‑MIMO definitely better than 2x2?
Only if your devices support it. Client radios must match to benefit. If they do not, even 16x16 will not help. Beamforming can still aid single‑stream clients, but multi‑user gains require compatible clients. [Elektroda, KOCUREK1970, post #17525609]
Which sub‑PLN‑400 models support alternative firmware?
Two standouts: ASUS RT‑AC58U (IPQ4018, 4‑core) with OpenWrt builds, and ASRock G10 with DD‑WRT. Tenda AC10 offers 11ac Wave 2 features, but lacks OpenWrt because of its chipset. Confirm firmware needs before buying. [Elektroda, datexxxxxx, post #17525472]
Is Xiaomi Mi Router R3P worth it around PLN 300?
It fits the budget but has trade‑offs. The stock firmware is modest and Chinese‑only. The Android app can be used in English. An alternative firmware, PandoraBox, exists. Consider warranty and availability before choosing it. [Elektroda, Nagus, post #17516504]
Is D‑Link DIR‑882 a safe budget pick?
It offers 4x4 Wi‑Fi and costs about PLN 440. However, it has little memory and can clog under network load. OpenWrt support for its Mediatek platform is limited. Choose it only if those caveats fit your needs. [Elektroda, Nagus, post #17516504]
How do I verify MU‑MIMO/beamforming and alt‑firmware support before buying?
Use this quick check before ordering.
  1. Find the exact model and chipset listed by the vendor.
  2. Confirm “MU‑MIMO” in the spec; second‑gen 11ac chipsets add it and beamforming.
  3. Check OpenWrt/DD‑WRT sites for your model’s builds and install guides. [Elektroda, Nagus, post #17516504]
Does the Qualcomm QCA9980 support 11ac Wave 2 and beamforming?
Yes. QCA9980 is an 11ac Wave 2 chipset used in the ASRock G10. “Beamforming is more effective the more antennas there are,” so 4x4 helps. This makes the G10 a strong beamforming candidate. [Elektroda, Nagus, post #17518767]
Does Tenda AC10 really support MU‑MIMO?
Sources conflict. One comparison concluded that, among the listed models, only ASRock G10 and ASUS AC58 offered MU‑MIMO. Always verify the chipset and official specs before purchase. [Elektroda, internick, post #17527578]
Are TP‑Link Archer C2300 or Netgear R7800 worth stretching for?
They perform better but cost more. The C2300 runs about PLN 500–600. The R7800, a 4x4 model with QCA9984, is around PLN 800–900. Asus and ZyXEL alternatives sit in similar ranges. Choose them if budget allows. [Elektroda, Nagus, post #17516504]
Is ZyXEL NBG6617 a viable alternative to ASUS RT‑AC58U?
It uses the same IPQ4018 chipset and doubles RAM to 256 MB. However, there was no ready OpenWrt distribution for it. The AC58U has OpenWrt builds available, making it more upgrade‑friendly. [Elektroda, Nagus, post #17527485]
Should I use one router or multiple access points across floors?
For two floors, consider a router without Wi‑Fi plus one access point per floor. This removes coverage worries and improves Wi‑Fi performance. It is often the most reliable layout for multiscreen homes. [Elektroda, Anonymous, post #17527656]
Is 512 MB RAM necessary today? Can exroot expand storage?
512 MB is not required today. Software evolves and needs more memory over time, though. Routers are closed devices; exroot can expand ROM but commonly causes later problems. Prefer enough native memory. [Elektroda, KOCUREK1970, post #17525609]
Can I replace router flash or add USB later?
Yes, skilled users sometimes replace flash chips or add USB. These hardware mods require experience and tools. Attempt them only if you know how and accept warranty risks. [Elektroda, makosuu, post #17525971]
