[Solved] Best Router Options for PLN 300: Archer C7, Wi-Fi, Print Server & Network Drive Support
rijkaard 6984 12
Which router costing about PLN 300 should replace the failing D-Link DIR-635 and provide reliable Wi-Fi, wired connections, QoS, a USB print server, and possible network-drive support in a reinforced-concrete apartment?
For this PLN 300 home network, the clearest recommendation is the Asus RT-AC1200G+, which was described as stable, offering good coverage, and receiving frequent software and security updates [#17774122] A single router may not cover the entire apartment through reinforced-concrete walls, so additional equipment may be needed if coverage is insufficient [#17772602] Before adding another router, check the current router’s WAN IP; if it is private, use a switch and quality access point instead of creating multiple NAT layers [#17772821] The purchaser ultimately selected the Asus RT-AC1200G+ [#17777062]
  • #1 17760600
    rijkaard
    Rate: 12
    Parents need a new router. their budget is about PLN 300.
    The sketch shows the layout of the apartment. In addition to the Wi-Fi connections that are marked, there are also phones (at least 3, sometimes 8).
    Best Router Options for PLN 300: Archer C7, Wi-Fi, Print Server & Network Drive Supportrodzic..PNG (11.53 kB)You must be logged in to download this attachment.
    At the moment, it is not possible to move the router.
    In addition to computers (3 pcs - 1 for 100% cable, one WiFi, the last of both options), there are two TVs and a printer - it will be connected via the network, so at least one USB port will be needed (preferably two - it is possible that there will be a network drive).
    Initially I thought about Archer C7 - will it be a good choice?
    1. The maximum amount that I can spend on the purchase: ~ 300 PLN
    2. Connection type: Optical fiber to the box in the corridor, twisted pair to the flat (NETICO)
    3. What plug is the cable ending with: RJ45
    4. Number of computers to be divided: 3
    5. QoS: YES
    6. Split bandwidth: need not have
    7. Additional requirements: Print Server (brother dcp j132w), network drive
    8. What will the device be used for: home network, multimedia, netflix, hbo go, WoT online games, WoW
    9. How many floors will it possibly have to cover the range *: 1 (skyscraper, reinforced concrete load-bearing walls)
    10. The equipment I currently have: DLINK DIR-635
  • #2 17762485
    barzwiszc93
    Help: 11
    Rate: 37
    It's very good that you have a D-link. Why are you changing it? Broke down? Is it tare, free? Or maybe you need a better range and connect more devices? If the latter, then maybe buy a better antenna, maybe a repeater, or a second router of the same brand.
    I had no coverage at home - thick walls, some crap router - because not mine, but I added a d-link repeater - it never hangs, it works smoothly and steadily. If anything hangs up - it's a router, which is simply Chinese.
  • #3 17762679
    rijkaard
    Rate: 12
    The router is already malfunctioning. Every few minutes the WIFi network is lost and they don't have internet, the router needs to be restarted. He served his years, first with me, then with my parents. Apparently his time has come. So it's time for a change.
  • #4 17771572
    rijkaard
    Rate: 12
    Seriously ? for almost 100 visits, nobody has any advice?
  • #5 17771789
    barzwiszc93
    Help: 11
    Rate: 37
    I will say this. It will be cheaper and faster if you do not use a cable to locate the Internet. However, if you must, I would limit the cables as much as possible.
    I am a fan of cables myself, but when it comes to saving money, that's what I would do - unless you already have cables installed, it's a different story.
    The second thing, if you need to have cables and change the router, buy something brand-name and the cheapest option, if you have thick walls, will be a d link or tp-link with good antennas. What model doesn't really matter. These companies don't crap. The limitation is money. The more you give, the better you are.
    I have access to the internet wirelessly. A tragic Chinese router - over which I have no influence. Notorious restarts when several devices are working. For example, a TP link repeater. It has been working for a year - it never crashed. It has 1 connector for a cable that I did not use and several devices work under wifi.
  • #6 17772602
    KOCUREK1970
    Help: 3863
    Rate: 5493
    Buy Asus. But do not expect that you will cover it with one equipment (these are not the times anymore).
    TP Avoid links.
  • #7 17772821
    IC_Current
    Help: 1499
    Rate: 2523
    Check if you absolutely need a router, because maybe the supplier has already installed one for you, and then it's better for you to buy a switch + a good quality access point.
    The easiest way to check is by logging into your current router and reading the IP address on the WAN interface. If it is from a private pool, it makes no sense to install an additional router and create multiple NAT.
  • #8 17774102
    rijkaard
    Rate: 12
    First of all, thank you for the answers
    Unfortunately, the devices for the cable would have to be equipped with WiFi cards (stationers) to work without cables. Additional cost.
    the available amount is PLN 300. Good antennas - most of the specifications show the strength of 5dBi in the ones I am reviewing, the only difference is the number of antennas.
    TP Avoid links.
    A colleague above recommends tp-link, and you advise against - :) and be smart here :) . And what about Asus will you recommend?
    The d-link has just replaced the router given by the service provider. Some Chinese parents had. D-link has been working for them for two years, but as I wrote, it's not working, that's why the exchange.
    From the last viewed:
    Asus RT-AC1200G + router - 4 antennas unfortunately not removable (one more than in e.g. c7) the price is also included
    D-Link AC1200 DIR-825 - as above
    TP-LINK Archer C1200
    TP-LINK Archer C7 (V5)
    TP-LINK Archer VR400
    what about the five for / against ???
  • #9 17774122
    KOCUREK1970
    Help: 3863
    Rate: 5493
    rijkaard wrote:
    The colleague above recommends tp-link, and you advise against it - and be wise here. And what about Asus you will recommend?
    Even this:
    rijkaard wrote:
    Asus RT-AC1200G +
    Very good reviews, stable with good coverage, frequent software updates, patching security holes, etc.
  • #10 17774188
    Staszek z Chełma
    Level 19  
    Help: 19
    Rate: 56
    I have used and are using the FritzBox
    it is a typical DSL router with VoIP gateway,
    with the ability to change the LAN output to the WAN input
    connected to the Arris CM820 modem (Multimedia)
    = you must also remember that each equipment has its own
    "life time" means that the lamps are still lit there,
    the time comes and it needs to be replaced.
  • #11 17774381
    rijkaard
    Rate: 12
    Thank you for your help.
  • #12 17774835
    hermes-80
    Help: 1177
    Rate: 743
    Nowadays, who advises against connecting stationary devices with a cable? There is nothing more stable - and flipping all the equipment that does not require it on wifi is a voluntary search for trouble. Cable is the only sure thing in ICT networks. If you plan to lay cables or have them, you connect everything stationary to the cable.
  • #13 17777062
    rijkaard
    Rate: 12
    I have no such intention :) One costs extra, two, worse quality :)
    After talking with the parents - the router was purchased - it was Asus RT-AC1200G +.
    I'll hook it up for them today
    Thank you for your interest in the topic
The discussion revolves around selecting a new router for a household with a budget of PLN 300. The user initially considered the TP-Link Archer C7 but sought advice on its suitability given the need for Wi-Fi coverage, multiple devices, and support for a print server and network drive. Various responses highlighted the importance of brand reliability, with recommendations for TP-Link, Asus, and D-Link routers. Users emphasized the benefits of wired connections for stability, while also discussing the necessity of USB ports for printer connectivity. Ultimately, the user decided on the Asus RT-AC1200G+ after considering several models, including TP-Link options and D-Link routers.
TL;DR: On a ~PLN 300 budget, expect router + extender; one repeater ran 1 year — "It never crashed." Wire stationary devices, check for double NAT, and pick USB/QoS as needed. [Elektroda, barzwiszc93, post #17771789]
Why it matters: This FAQ helps households replacing unstable routers in concrete-wall flats choose brands, features, and coverage add-ons.
Whats the best router under PLN 300 for concrete-wall apartments?
In this thread, Asus RT‑AC1200G+ stood out in this budget. A contributor highlighted stable operation and good coverage. They also praised frequent firmware updates and security patches. That combination suits multi-device homes needing dependable service. [Elektroda, KOCUREK1970, post #17774122]
Which model did the OP finally choose?
After discussion, the buyer selected the Asus RT‑AC1200G+. They planned to install it the same day for their parents. That closed the purchase decision for this setup. [Elektroda, rijkaard, post #17777062]
Should I avoid TP-Link entirely?
One advisor cautioned against TP‑Link in this case. They said to buy Asus instead. They also warned that one device will not cover a whole flat. "Do not expect that you will cover it with one equipment." [Elektroda, KOCUREK1970, post #17772602]
Do wired connections still matter for PCs and TVs?
Yes. "Cable is the only sure thing in ICT networks." Wire stationary devices for stability. That reduces Wi‑Fi contention and random dropouts. Save Wi‑Fi for mobiles and tablets. [Elektroda, hermes-80, post #17774835]
I cant move the routerhow do I extend coverage?
Add a repeater or a second router configured as an access point. One user deployed a TP‑Link repeater. "It never crashed" across a full year. That stabilized an unreliable ISP-provided router. [Elektroda, barzwiszc93, post #17771789]
How do I check if I even need another router (to avoid double NAT)?
Use this quick check: 1. Log into your current router. 2. Read the WAN IP address. 3. If it is private, avoid adding another router; use a switch plus a good access point. This avoids creating multiple NAT. [Elektroda, IC_Current, post #17772821]
What ports and features should I prioritize for this setup?
Select an RJ45 WAN input from the fiber handoff. Enable QoS for traffic prioritization. Require at least one USB for a print server and possible network drive. The plan involves a Brother DCP‑J132W and shared storage. [Elektroda, rijkaard, post #17760600]
Will one router cover a flat with concrete walls?
Expect gaps in reinforced apartments. "Do not expect that you will cover it with one equipment." Add access points or extenders where signal drops. Place nodes thoughtfully for best results. [Elektroda, KOCUREK1970, post #17772602]
My current router drops Wi‑Fi every few minutes. Fix or replace?
Replace it. That behavior often signals end of life. As one user put it, "the time comes and it needs to be replaced." Install a modern router or AP to restore stability. [Elektroda, Staszek z Chema, post #17774188]
Does TP-Link Archer C7 still make sense around PLN 300?
It appeared on the shortlist with Asus RT‑AC1200G+, Archer C1200, and D‑Link DIR‑825. Evaluate based on USB, print server needs, and coverage planning. Make the final call after confirming placement constraints. [Elektroda, rijkaard, post #17774102]
How many devices can this kind of setup handle?
This scenario planned for 3 PCs, 2 TVs, and 3–8 phones. That many clients benefit from QoS and wired backhaul. Use Ethernet for desktops and TVs to keep Wi‑Fi clear. Balance load across 2.4 and 5 GHz bands. [Elektroda, rijkaard, post #17760600]
What plug type and ISP handoff should I plan for?
Expect optical fiber to a building box, then RJ45 twisted pair into the flat. Choose a router with an RJ45 WAN port to match. That avoids adapter hassles at installation. [Elektroda, rijkaard, post #17760600]
Does the Asus RT‑AC1200G+ have removable antennas?
No. It uses four fixed antennas. Focus on placement and added access points instead of antenna swaps. That yields better coverage gains. [Elektroda, rijkaard, post #17774102]
