LG 42 LED TV: No Picture with Sound, Contours Visible, Backlight Issue, Repair Possibilities
tomaszekb24 24825 5
  • #1 16459195
    tomaszekb24
    Yesterday I turned off the LG 42 LED TV. Today I attached and flashed only the sign of LG. A sound is heard. As I get closer to the screen you can see the outlines. For example, I can see the contours of the menu. Almost the nose at the screen can be chosen from the menu. I tried hard reset tv and it did not help. I turned on the tv and checked the capacitors and everything in my opinion ok. The symptom was like there was no backlighting of the picture. I have no idea what to do. I am asking for advice. Is it worth fixing what a defect is? In whether or not a matrix should fall.
    Dydelmax
    Help: 654
    Rate: 965
    Provide the exact model of this TV. Give also his cast (markings of the motherboard, power supply, etc.), you can upload good quality photos of these components on the Forum - you will be able to tell specifically what you should "take a look at".
    Check the voltage supplied by the power supply.
  • #3 16459281
    tomaszekb24
    LG 42LA620S model in my opinion everything on the power board is ok. Lack of blackened elements, bulging capacitors. For me, the problem will be the lack of matrix backlight. I do not have a meter and it's hard for me to check the voltage on the power supply.
    Added after 15 [minutes]:
    https://obrazki.elektroda.pl/6812259100_1494092874.jpg
    https://obrazki.elektroda.pl/8772220600_1494093001.jpg
    Photos added for advice.
    Andrzej4567
    Help: 26
    Rate: 252
    You have a broken backlight. At 80%, I'm damaging the backlight in the matrix, and 20% damage to the power supply. One way or another you need to take measurements in the power supply and the matter will be cleared up.
  • #5 16460863
    tomaszekb24
    However, it turned out that the matrix backlight was damaged. I replaced the yellow power supply board and the same. The question is whether such a backlight can be repaired on its own? How to do it and whether it pays off? If so, I would ask for step by step help how to do it? Thanks in advance for the hint.
  • #6 16460987
    Andrzej4567
    Help: 26
    Rate: 252
    tomaszekb24 wrote:
    Is it profitable?
    It's profitable.
    tomaszekb24 wrote:
    How to do it
    If you do not have experience with matrices, it is better not to take it, it is easy to damage the matrix.
