LG 42LN5404 LED Backlight Issues: Troubleshooting & Power Supply Replacement Options
titanmascha 2913 1
  • Intermittent LED output voltage suggests power supply fault
    #1 19686001
    titanmascha
    I have a LG 42ln5404 TV in which the backlight does not work. The screen is completely black, but there is sound. At the beginning, I checked the status of the LEDs - visually they all looked ok, but with power only a few LEDs are blinking low every 4 to 6 seconds.
    The next step was to examine the voltage at the power supply with the LED connector (EAX64905301 (3.1) power supply).
    I checked the voltage for the Led-output, but it switches from 0.2V - 3.5V every 4 to 6 seconds. So my conclusion was that the power supply is defect. Does anyone know how I can probably fix it or where I can order a new power supply?
    Thank you very much!
    Sebastian LG 42LN5404 LED Backlight Issues: Troubleshooting & Power Supply Replacement Options LG 42LN5404 LED Backlight Issues: Troubleshooting & Power Supply Replacement Options
  • #2 19698095
    maksar
    Help: 177
    Rate: 1030
    titanmascha wrote:
    So I came to the conclusion
    Incorrect application.
    titanmascha wrote:
    how can i fix it
    Replace backlight, ALL.
