Opel Astra G 1.6 8v: Engine Oil Consumption & Sweating Around Yellow Frame - Causes & Solutions
xSirLancerAlotx 7707 4
  • #1 16459275
    xSirLancerAlotx
    Help: 7
    Hey. for some time I noticed that my Asterka is taking oil and I have to add a little bit from time to time. and today I opened the mask and saw disturbing sweating around the yellow frame. The car is without gas, the smoke is normal, Anyone has any idea what it could be?
    PS
    I have no idea what the previous owner was flooding for oil, I pour the original 10w40 from GM, but I think some sealants have gone
    best regards
    • Opel Astra G 1.6 8v: Engine Oil Consumption & Sweating Around Yellow Frame - Causes & Solutions 18405629_458821761123844_655037607_o.jpg (1.67 MB) You must be logged in to download this attachment.
  • #2 16459287
    piotrekwoj1
    Help: 947
    Rate: 3433
    As you can see it flies with oil filler cap and gaskets under the valve cover.
  • #3 16459325
    xSirLancerAlotx
    Help: 7
    @ piotrekwoj1
    is the seal under the valve cover the famous "Keyboard seal"?
    Do you think that there will be no problem after the exchange? I suspect it or Odm, because I heard that it was the accident of these X16SZR engines
  • #4 16459837
    piotrekwoj1
    Help: 947
    Rate: 3433
    Yes, this is how you do everything right, it should not go there.
  • #5 16459858
    ociz
    Help: 1379
    Rate: 3486
    You can easily get rid of leaks in any normal workshop, but the fact that the engine burns oops is only a scammer will tell you that he will repair without a general overhaul that will exceed the value of the car.
