Octavia II - problem with the assembly of the towbar harness - fog
lukasz921 6177 10
How do I connect the fog light wiring on a Starc 399017 towbar module when the rear fog and position light share the same bulb?
Connect the module’s gray wire to the car’s fog-light wire in the rear lamp, and ignore the gray-white wire. The forum answer says the module detects the different voltages/pulses, so the fog light should work without cutting or rewiring the lamp circuit [#16461072] Another user confirmed that in practice the gray wire always goes to the fog light and that connecting gray and gray-white as shown in the diagram had no effect, so the simpler connection works [#16461454] For module power, use the cigarette lighter in the trunk on an estate, or the thicker red wire from the fuse box if it is not an estate [#16461875] If you have parking sensors, disconnect the ground from the sensor control unit and connect that wire to the towbar control unit instead [#16461953]
  • #1 16459622
    lukasz921
    Rate: 35
    I have a problem with connecting the fog lamps. Well, in the set I received a slightly different instruction than on the manufacturer's website, the module is a universal module Starc 399017.
    The instruction I received:
    Instructions on the website:
    http://www.starc-automotive.com/files/starc/u...bersicht/Produkt-Liste_A3_06_Englisch_web.pdf
    And now I do not know how to attach the fog lamps, In my case the fog lamps are together with the position light on the same bulb.
    I would be grateful for your help because I am completely stupid. It's about the difference in points 3 and 11-12
    maxcars
    Connect the gray one from the module to the fog lamp in the lamp and do not cut anything (the module recognizes voltage, position about 3V, fog light 12V !. The fog light is controlled by pulses from the switch (you turn it on on the car and trailer or on the trailer itself).
    Added after 16 [minutes]:
    You can connect positional also to these small bulbs in the rear lamp there is only 12V
  • Clarifying gray and gray-white fog harness wire functions
    #3 16461285
    lukasz921
    Rate: 35
    Thanks for your help, I just have a question. Because I have 2 cables from the module for fog lamps.
    Gray - the symbol of the switch, i.e. control, and Gray - white - the symbol of the fog light bulb.
    So if I switched the positions to this "other" bulb, I should connect the gray cable to the position / fog lamp? So what about the gray and white cable? Unless it is the gray option that is the control, and the gray and white option is always the trailer and the car on?
    Lukasz
    Gray fog-wire connection fails with inconsistent switching behavior
    #4 16461454
    maxcars
    I connected this module several times and always the gray link to the fog one (cutting the wire and connecting the gray and gray-white ones to the diagram, respectively, did not have any effect). Switch control: 1 turn on - the effect will light up on the car and trailer, 2 turn off - it will go out on the car - it lights up on the trailer, 3 turn on - it lights up on the car and trailer, 4 turn off - it will go out on the car and trailer.
    Paul.
  • #5 16461839
    lukasz921
    Rate: 35
    So gray - white is left unconnected? Thanks a lot for help on Saturday I struggled with it and it was not effective. Do you think that you can connect the power supply plus under the fuse box under the driver's knees to one of the thicker wires?
  • #6 16461875
    maxcars
    Forget gray and white! If it is a station wagon, you can supply it from the cigarette lighter (trunk, right side), if not the station wagon, then the fuse box is thicker red.
  • #7 16461931
    lukasz921
    Rate: 35
    And there are no puzzles with support for reversing sensors? I unplug the ground from the reversing sensors from the sensor control unit and connect the cable from the control unit that supports the hook.
    maxcars
    Exactly.
  • #9 16461958
    lukasz921
    Rate: 35
    Thanks again tomorrow.
  • #10 16494038
    lukasz921
    Rate: 35
    Everything works fine, as Maxcars wrote
  • #11 20035637
    lukaszbujnowski1985
    Hello, I also have a problem with connecting the fog lamp cable; (can I connect the position from the module to these single parking spaces on the side of the lamp and the cable from the fog lamps to the wire from the position in the plug in the rear lamp of my skoda octavia 2 thanks
    @ lukasz921
The discussion revolves around issues with connecting fog lamps to a towbar harness in a Skoda Octavia II using a universal module, Starc 399017. The user received conflicting instructions regarding the wiring connections for the fog lamps, which share a bulb with the position light. Responses suggest connecting the gray wire from the module to the fog lamp, while the gray-white wire should remain unconnected. Additional advice includes sourcing power from the cigarette lighter or the fuse box. The conversation also touches on integrating the setup with reversing sensors.
