LG G3 D850 Black Screen Issue: Unresponsive & Detected as Qualcomm HS USB QDLoader 9008
dozjge 5004 6
  • #1 16464019
    dozjge
    Hello, I have a problem with my phone. The phone suddenly turned off and does not respond to anything. When I connect it to my computer, it looks for it as qualcomm hs usb qdloader 9008. Please help, how can I fix it?
  • #3 16464226
    dozjge
    I did according to 2 guides. In the BoardDiag program, the phone does not pass the last sdram test, as if all files are uploaded but the phone does not turn on, it still has a hard brica
  • #4 16464311
    nutergsm
    Help: 1034
    Rate: 1665
    Well, that's the service.
  • #5 16464340
    dozjge
    And what can the service do then?
  • #6 16464418
    nutergsm
    Help: 1034
    Rate: 1665
    They will try to fix the phone with the right equipment.
  • #7 16464520
    pyzdraaaa
    You probably have emmc damaged (needs low format). A frequent malfunction of LG and new smartphones. It remains to be put by the emmc programmer in the worst case replacement emmc and programming.
The LG G3 D850 has encountered a hard brick issue, becoming unresponsive and detected as Qualcomm HS USB QDLoader 9008 when connected to a computer. Users suggest that the problem may stem from a damaged eMMC, which could require low formatting or replacement by a professional service. Some users have attempted various recovery methods, but issues persist, particularly with the SDRAM test in diagnostic software. Seeking professional repair services is recommended for effective resolution.
