Problem black screen s5 - Samsung s5 - black screen after falling
Domin339 33972 9
Why does my Samsung Galaxy S5 have a black screen after a fall even though the phone still seems to power on and respond to touch?
Your Galaxy S5’s black screen after the fall is most likely a cracked display or a loose display ribbon, not a software issue. You can try looking at the screen under strong light and at an angle for internal cracks, since the glass may look intact from straight on [#16578139][#16578143] If the display is broken, the phone can still be connected to a monitor or TV via MHL to get data off it [#16578163] The ribbon/connector is under the screen on this model, so checking or reseating it means opening the phone and usually peeling off the display; otherwise a service repair is the practical option [#16578212][#16578444]
  • #1 16578110
    Domin339
    Rate: 13
    Hello, I have a Samsung gakaxy s5 sm-g900h phone and after the fall of about 30-40 cm (being in the case) the screen is black.
    I was watching TV on the screen mirroring function and when I wanted to stop the movie I accidentally pulled the cable from the charger (the phone was charging) and it came down and it was just a black screen, I could still see what was on the screen, and touching the phone I was able to see that something is happening - in other words, the touch has not fallen. By resetting the phone I can hear the startup sound.
    The buttons on the sides first worked normally for a while. Now the back button is not lit at all, while the button on the left (option?) Lights up constantly. I am unable to connect again through screen mirroring because I have a code and it does not leave me unlock the phone, enter the notification panel and run this function
  • #2 16578139
    makosuu
    Help: 369
    Rate: 370
    The display has cracked or the ribbon has slackened. Rather, get ready for the first option, but you can also check the connector.
  • #3 16578141
    Domin339
    Rate: 13
    Only that no matter what angle I look at the screen there is no crack. There are only old scratches
  • #4 16578143
    makosuu
    Help: 369
    Rate: 370
    If you want to see it so much, look under strong light and at an angle. Only we do not talk about the glass and the display.
  • #5 16578153
    Domin339
    Rate: 13
    Is anything that can be done without returning the phone for service / repair?
  • #6 16578163
    makosuu
    Help: 369
    Rate: 370
    I've already written - you have a chance that the tape has detached from the display, verify it, the more that you claim that you can not see the cracks or at least you do not write anything.
    However, if the display has broken, you can connect it to the monitor or TV by MHL. But I assume that's not the point. You can also repair it yourself, then you do not give it away :D
    Of course, something could have been damaged on the disc, but it is rather unlikely.
  • #7 16578200
    Domin339
    Rate: 13
    Oh yes, I have not noticed (maybe blind) any such "internal" cracks.
    As for the tape, I have no idea how to verify it and I can not find any sensible source of information on how to do it.
    Apparently, it remains to deliver to some service, and if the repair will be expensive, it will drain this phone and return to the old one.
  • #8 16578212
    makosuu
    Help: 369
    Rate: 370
    Under the back cover you have such a small plug with a screw screwed in, there is a tape under it.
  • #9 16578231
    Domin339
    Rate: 13
    Unfortunately, I do not understand, if you want, could you please tell me? (the first better photo from the internet)
  • #10 16578444
    makosuu
    Help: 369
    Rate: 370
    I'm sorry, I was tired of the fingerprint from the fingerprint reader. It was late ;) . In fact, at this point you can probably end the topic because the tape is under the display and would not be detached. And I see that you do not want to combine too, it's better to give a phone call to the site.
    Here you have this ribbon, it's under the screen. To get to her you would have to peel off the screen.
The discussion revolves around a Samsung Galaxy S5 (SM-G900H) experiencing a black screen issue after a fall. The user reports that the touch functionality remains operational, as they can hear startup sounds, but the display is unresponsive. Responses suggest potential causes such as a detached ribbon cable or internal cracks, despite the user not observing any visible damage. Suggestions include checking the connector and considering self-repair options, although the user expresses uncertainty about performing these checks. Ultimately, the consensus leans towards seeking professional repair if the issue persists, as accessing the ribbon cable requires disassembling the device.
