Wiring a 220V Single Phase Motor With 5 Wires to a 6-Terminal Rotary Drum Switch
606 18
How do I wire a 220V single-phase motor with U1/U2/Z1/Z2 and PE to a 6-terminal forward-off-reverse drum switch so it runs forward and reverse?
Wire the drum switch so mains live goes through terminals 5→6, then connect terminal 6 to terminal 1 and motor U1, connect neutral to terminal 4 and motor U2, and connect Z1 to terminal 2 and Z2 to terminal 3; if the motor runs the wrong way, swap Z1 and Z2 [#21681256][#21681260] This assumes the switch’s 5/6 contacts are the on/off pair that close in Forward/Reverse and open in Off, and that the capacitors are already wired inside the motor [#21681256][#21681258] The reply also advised checking the windings first with an ohmmeter, since U and Z are likely the run and start windings [#21681254][#21681260] The thread later confirmed the motor was made to run forward/reverse and that this wiring approach worked in practice [#21681255][#21681262] The main caution given was to treat this as hazardous mains wiring and get qualified help if possible [#21681256][#21681258]
  • Requesting wiring diagram for forward-reverse drum switch
    #1 21681253
    Charles Hallam
  • Check winding continuity and capacitor wiring first
    #2 21681254
    David Ashton
  • #3 21681255
    Charles Hallam
  • Suggested wiring for forward/reverse drum switch
    #4 21681256
    David Ashton
  • #5 21681257
    Charles Hallam
  • Use breaker and ammeter for safe motor testing
    #6 21681258
    David Ashton
  • Clarifying mains live and switched live wiring
    #7 21681259
    Charles Hallam
  • Explains mains live and winding identification for switch wiring
    #8 21681260
    David Ashton
  • #9 21681261
    Charles Hallam
  • #10 21681262
    David Ashton
  • #11 21681263
    Charles Hallam
  • #12 21681264
    David Ashton
  • #13 21681265
    Charles Hallam
  • #14 21681266
    David Ashton
  • #15 21681267
    Charles Hallam
  • #16 21681268
    john sam
  • #17 21681269
    john sam
  • #18 21681270
    rohan wan
  • #19 21681271
    sunil agarwal
The discussion addresses wiring a 220V single-phase motor with five wires (PE ground, U1 black, U2 brown, Z1 black, Z2 blue) to a six-terminal rotary drum switch designed for forward-off-reverse operation. The motor is a capacitor start/capacitor run type, capable of forward and reverse rotation, with capacitors already integrated. The wiring challenge involves correctly connecting the motor windings and mains supply to the drum switch terminals to enable directional control. The motor windings include a run winding (U) and a start winding (Z), with some terminals internally bused (Z2, U2, and V1). The recommended wiring scheme connects mains live through the drum switch terminals 5 and 6, switching the live feed to terminal 1 (U1), with neutral connected to terminal 4 (U2). Terminals 2 and 3 connect to Z1 and Z2 respectively, allowing polarity reversal of the start winding for direction control. Although the suggested wiring involves switching neutral instead of live in some cases (not best practice), it functions correctly. Safety precautions include using an appropriate circuit breaker (10-16A) and consulting qualified electricians due to the motor's high power and complexity. The original obsolete forward-off-reverse switch was replaced with a Dayton 2x441 rotary drum switch. The discussion emphasizes verifying winding continuity with an ohmmeter and understanding the motor's internal wiring before proceeding.
TL;DR: For a 220 V single‑phase motor (nameplate 8 A) on a 6‑terminal drum switch, wire live through the switch and swap Z1/Z2 for reversing; “get someone with experience.” [Elektroda, Anonymous, post #21681258]
Why it matters: This FAQ helps DIYers wire a reversible cap‑start/cap‑run motor safely and diagnose common switch/motor lead issues.
How do I wire U1, U2, Z1, Z2 to a 6‑terminal drum switch for forward/reverse?
Route mains live to switch 5, then from 6 to switch 1 and motor U1. Connect neutral to switch 4 and motor U2. Put Z1 on switch 2 and Z2 on switch 3. This reverses the Z winding polarity relative to U for direction control. Use the center‑off position. [Elektroda, Anonymous, post #21681256]
Which conductor should the drum switch interrupt—live or neutral?
Interrupt the live (hot) conductor with the common pair (5/6). Switching the neutral leaves energized internals and is bad practice, even if the motor runs. Correct it by moving the supply to switch the live side. [Elektroda, Anonymous, post #21681262]
What’s a safe 3‑step test after wiring the switch?
  1. With the breaker OFF and switch at OFF, turn the breaker ON; nothing should run.
  2. Breaker OFF, switch to Forward, breaker ON; motor should run forward.
  3. Breaker OFF, wait for a full stop, switch to Reverse, breaker ON; motor should run reverse. [Elektroda, Anonymous, post #21681258]
The motor runs the wrong way—what’s the quickest fix?
Swap the Z leads on the switch: move Z1 to the Z2 terminal and Z2 to the Z1 terminal (swap 2 and 3). Always stop the motor fully before changing direction. [Elektroda, Anonymous, post #21681258]
What do the U and Z lead markings mean on this motor?
U1/U2 are the run (main) winding leads, while Z1/Z2 are the start winding leads. The run winding usually shows lower resistance; the start winding may include a series capacitor, limiting direct resistance checks. “Mains Live is the live or active wire.” [Elektroda, Anonymous, post #21681260]
Do I need external capacitors on the switch?
If the motor already has internal cap‑start/cap‑run components wired, no external capacitor wiring is needed at the drum switch. If external, place the capacitor in series with Z1 or Z2 before the switch, per the motor’s diagram. [Elektroda, Anonymous, post #21681254]
Is a center‑off drum switch required?
Yes. A center‑off prevents sudden reversal while spinning, which stresses the motor and switch. “It’s not good to suddenly put a motor in reverse.” Choose a Forward‑Off‑Reverse switch. [Elektroda, Anonymous, post #21681254]
What breaker size works for an 8 A, 220 V single‑phase motor during testing?
Use a 10 A breaker; if nuisance tripping occurs on start, step to 15/16 A. Place the breaker upstream so you can stand clear of the drum switch during first energization. This approach limits fault energy. [Elektroda, Anonymous, post #21681258]
What if there’s continuity between U and Z windings?
If the U and Z windings show continuity between them, the motor may not be reversible in the way expected. Check the nameplate and diagram; the four‑lead layout without continuity is promising for reversing. [Elektroda, Anonymous, post #21681254]
How do I identify which wire is Mains Live for terminal 5?
Mains Live (hot/active) is the supply conductor from your breaker’s output. Connect that to switch terminal 5 so 5/6 control power to the motor. Neutral goes to the designated neutral terminals/points. [Elektroda, Anonymous, post #21681260]
My diagram shows Z2, U2, and V1 factory‑bussed together—what does that imply?
Some motors ship with internal links (bus bars) tying Z2, U2, and V1. That changes how external connections behave. Respect the factory bus and follow its diagram; don’t remove links unless the motor’s documentation instructs it. [Elektroda, Anonymous, post #21681265]
Is it okay to proceed without an electrician?
It’s strongly discouraged for large motors. Errors can cause catastrophic failure. An experienced electrician should verify connections and oversee testing. “But try and get someone with experience on something like this.” [Elektroda, Anonymous, post #21681258]
Which rotary drum switch model was used successfully here?
A Dayton 2X441, a 3‑position Forward‑Off‑Reverse drum switch with six terminals, was used and confirmed functional. Always match switch ratings to the motor. [Elektroda, Anonymous, post #21681255]
