The BMW E46 estate wagon does not work with the rear wiper and washer system
dj_master0 19635 12
How do I diagnose and fix an intermittent rear wiper and washer failure on a BMW E46 Touring?
The fault is most likely in the rear wiper motor/controller assembly or its contacts, so clean the ground and the two contact blades that touch the mechanism housing—one in the motor and one at the black controller box [#16488029] If the wiper still behaves randomly or the washer pump has no voltage, replace the controller/driver mounted with the motor; one reply says swapping that controller restores normal wiper and washer operation [#16505911][#16505273] Use a meter to check voltage at the rear wiper and washer circuits, starting under the steering wheel and tracing the wire colors to find where the signal stops [#16485408] Another reply warns that spontaneous activation can also be caused by a short circuit or puncture in the wiring [#16495123]
  • #1 16484771
    dj_master0
    Rate: 28
    Hello, I have a problem with the bmwe46 estate, the rear scoop and the sprayer does not work. I crumpled plugs, cables and it does not work. Sometimes when I leave and the valves are closed, it will surprise and work for some time. Does anyone know which wirebag with a bunch of wires is from the wiping? Because I have 2 on the right and one on the left.
    Added after 35 [minutes]:
    I will add that the doormat is not obliterated
  • #3 16484958
    dj_master0
    Rate: 28
    There is nothing in this manual on this subject
  • #4 16485408
    13Rycerz
    Rate: 9
    And the meter? Turn on the wiper and check the voltage. Then turn off and check again where the signal will not be your wiper cable. Similarly with the washer. you check it all under the steering wheel. or when the cables are colored, look into the wiper and washer - check the color and the same under the steering wheel and then the cable to be replaced. It should help unless the fault lies elsewhere ...
  • Cleaning motor and controller ground contacts fixed wiper operation
    #5 16488029
    dj_master0
    Rate: 28
    I cleaned the rear squeegee, I unscrewed the whole mechanism, I greased everything because something worked hard. The squeegee works but I do not know why each time the ignition comes on, the moments come and go, then it works ok, and the sprayer still does not work.
    Added after 4 [minutes]:
    I would add that the mass of the wiper motor on the mechanism's casing was not leading, there are two blades that contact the mechanism housing, one in the motor and the other at the controller (black box) need to be cleaned. After this operation the wiper was working.
  • #6 16495123
    13Rycerz
    Rate: 9
    This spontaneous inclusion may be caused by a short circuit / puncture
  • #7 16505273
    dj_master0
    Rate: 28
    There is no tension on the spray pump, and the wiper will activate every time the key is turned. This stops as it pleases, later when it starts after the car has been started, it normally responds to the switch on the steering wheel.
  • #8 16505911
    Jackall
    Help: 77
    Rate: 396
    Replace the controller with the motor, it will start to operate normally the wiper and washer.
  • #9 16534965
    dj_master0
    Rate: 28
    where will I buy such a driver?
  • #10 16535507
    Jackall
    Help: 77
    Rate: 396
    On the back with the motor, unless you hit damaged, you will only pay for the driver. But first, dismount your driver, maybe you can fix it.
  • #11 17178924
    Introwertyk6
    Hello, I have the same problem as the author in E46 320d COMPACT
    The rear wiper has stopped coming back, it stuck ...
    I undressed the mechanism and, of course, the classic defect, the plastic wheel had molded teeth and the whole mechanism was heavily sated ... The gear I bought new >>>
    http://allegro.pl/bmw-e46-compact-silniczek-w...DQ2ZWM2YTA4MTIwOGYwYmYzMzEyOTU2OTY0NWU1MTE%3D
    I cleaned everything, put on grease, moved it and put it together ...
    It works!
    But not completely...
    When the ignition is switched on, from the position of the switch on the steering wheel, the wiper turns on and the engine performs several movements like the washer and sometimes stops in a different position than the starter, moreover the washer pump does not work (the beam does not give tension) Everything worked properly before pulling out .. .
    Conclusion ... Module (driver which I took out with the mechanism) I checked to the exact, the plate is clean and perfect, nothing got there ... I cleaned the contact not yet conductive and I got on once again convincing that this element is ok, but the problem continues ...
    The wiper turns on when the ignition and the washer pump nothing ... Using the handle on the steering wheel to the first position, i.e. one passing the wiper also turns it on for several cycles (like for the washer)
    Does anyone have an idea what to do? I can not find the driver itself anywhere, everywhere with the whole mechanism it is and I do not have to check another ... In the eventuality I suspect the comfort module (but also looked ok and would not break down in just one day while removing the rear wiper mechanism) .
    The only thing I've done is this mechanism ...
    On this plastic wheel (original) there was a small magnet, on the replacement there is no place for it, I do not know why it was to be used ... Or holding the wheel into the casing or maybe something with electrics?
    I am asking for help, symptoms identical to the author's ...
    Maybe someone has the same car and lend it to its driver to check?
  • #12 17187087
    Introwertyk6
    Anyone have any idea suggestion? Maybe this module has been reset and it somehow sets?
    It's not possible that I damage it ...: /
  • E46 compact gear wheel mismatch and washer loss
    #13 18113429
    aarahon
    Introwertyk6 wrote:
    The wiper turns on when ignition and the washer pump nothing ...
    Hello, if so, how did you solve your problem?
    Because what the quote is is not a matching gear.
    The gear wheel for BMW E46 Compact is only one and does not fit other models due to:
    a) another place to attach the magnet to the sensor - on the wheel you bought is blinded, you need to cut the mandrel which is in the magnet holder and insert it as on the original wheel, then the wiper controller will adapt but:
    b) the wiper bolt spindle spacing is different, the magnet mounting place is also different so the wiper has a much greater movement which causes the wiper to slide down on the flap.
    You can try wiper transplant from focus mk1 before lift (only hatchback) but we lose the washer in the wiper arm.
    Anyway, let me know how it went.
The discussion revolves around a malfunctioning rear wiper and washer system in a BMW E46 estate wagon. The original poster reports intermittent operation of the rear wiper and washer, despite checking plugs and cables. Various users suggest troubleshooting steps, including checking voltage with a meter, inspecting the wiper motor and controller, and cleaning connections. One user mentions that the wiper motor's mass connection may need cleaning. Another suggests replacing the controller with the motor for proper functionality. The conversation also touches on issues with the mechanism's gear and potential short circuits affecting operation. Users share experiences with similar problems in other BMW models, indicating that the issue may be common across the E46 series.
