Maximizing Gain for a 30-Year Old VHF Antenna for RTCN Chorągwica - Channel 7 Reception
xXMatrixx 18099 15
How can I improve an old VHF antenna to reliably receive channel 7 from RTCN Chorągwica at about 80 km away?
You should not try to boost that old attic antenna; the replies say it appears incomplete/modified and, with your 80 km distance and difficult terrain, the practical solution is to replace it with a proper VHF antenna [#16466853] A compact ready-made option repeatedly recommended is the CA-RTV 6 VHF antenna [#16466595][#16466964] If you want to build one yourself, the suggested source for dimensions is antenna handbooks by Bieńkowski, Bator, or Kapczyński rather than a guessed UHF-style design [#16474537] For VHF/MUX8 reception the antenna must be mounted in the correct vertical polarization, and for CA-RTV6 the mount should be on the side boom; the rear mount is not suitable for vertical polarization [#16476819]
  • #1 16466496
    xXMatrixx
    Hello!
    Due to the appearance of additional channels on the VHF, I would like to receive them. I found in the attic probably with a 30-year antenna, most likely for the VHF band. Due to the fact that I live about 80 km from the transmitter I need an antenna with a large profit. I bought a balun for the antenna (picture in the attachment). I am asking for advice on how to increase its profit (it can extend, maybe an amplifier) and whether the dimensions are appropriate. I apologize in advance for naming, but I have a very basic knowledge on this subject. Thanks for the help! Attachments of the antenna in the attachments.
    Dipol (width) 64 cm
    Dipol (height) 6 cm
    Distance of the first crosshead from the second 27 cm
    The distance from the dipole to the 30 cm reflector
    The distance between the crossbeams 40 cm
    The width of the reflector arms 51 and 56 cm
    The width of the first crossbar is 74 cm
    PS: I am interested in receiving from RTCN Chorągwica - channel 7 191.5 MHz. Maximizing Gain for a 30-Year Old VHF Antenna for RTCN Chorągwica - Channel 7 Reception Maximizing Gain for a 30-Year Old VHF Antenna for RTCN Chorągwica - Channel 7 Reception Maximizing Gain for a 30-Year Old VHF Antenna for RTCN Chorągwica - Channel 7 Reception Maximizing Gain for a 30-Year Old VHF Antenna for RTCN Chorągwica - Channel 7 Reception
  • #2 16466545
    Włodzimierz Wojtiuk
    Level 32  
    Help: 231
    Rate: 272
    Farciarz, others have scraped away and now they have to buy!
    The antenna is poorly assembled. It can be like this:
    Channel 12.
    Here you can train:
    https://www.elektroda.pl/rtvforum/topic1962085.html#9358976
    https://emimaps.emitel.pl/
  • #3 16466558
    xXMatrixx
    Are there any dimensions? Because I was looking on the internet and found only on UHF. And how profitable at such a distance? I will add that I put it in the room, I made a manual search and found something, but unfortunately you could not see anything
  • #4 16466595
    LeDy
    Help: 1989
    Rate: 2930
    I suggest this one because it's a bit small. VHF CA-RTV 6 Maximizing Gain for a 30-Year Old VHF Antenna for RTCN Chorągwica - Channel 7 Reception
  • #5 16466607
    xXMatrixx
    It seems to me that the dipole is attached correctly, because there are factory holes. It is possible that it was longer. I can ask for dimensions because nowhere on the forum and on the internet I can not find (only UHF). Thank you for your help
  • #6 16466853
    M.Mikolajski
    Help: 13
    Rate: 22
    The antenna is evidently complex, incomplete and carries traces of transformation - use the proposal kol.Ledy of this you will not build anything for the distance you give, because the terrain is difficult
  • #8 16466964
    Fotodetektor
    Level 30  
    Help: 101
    Rate: 335
    I also recommend it. Well done and works best with those I tested.
    Jedyny mankament is the connector symetryzator; /
    The compression connector does not go well into the can, i.e. you need to seal additionally. The eraser in the set is only suitable for the F screwed.
    I reported it in the company and wonder if it will improve ?!
    OMNI-SAT
    WP 11, Wołów, 56-100 | Company Website: www.omnisat.pl
  • #9 16470510
    M.Mikolajski
    Help: 13
    Rate: 22
    xXMatrixx wrote:
    What do you think about the antenna design from this page
    Well, to work - you can see self-denial and desire and so build and notify of results - good luck
  • #10 16471292
    Włodzimierz Wojtiuk
    Level 32  
    Help: 231
    Rate: 272
    xXMatrixxi wrote:
    I think the author has a little practice on concentric cables ;-)
    Yeah, in Krakow libraries the book by J. Batora is!
  • #11 16472263
    M.Mikolajski
    Help: 13
    Rate: 22
    The author of the practice does not have, but he was inspired by an accidentally found old antenna somewhere in the attic - he wants to build the antenna he gains knowledge and practice - if he was comfortable he would not only bother to buy an antenna in the net or shop - he found the material on the net and something act at the same time learning - I support :spoko:
  • #13 16475168
    Włodzimierz Wojtiuk
    Level 32  
    Help: 231
    Rate: 272
    It was not about this author, but about the author of the copper UHF antenna project ;-)
  • #14 16476460
    M.Mikolajski
    Help: 13
    Rate: 22
    I know what the author of the topic found on the net and I know that other known sources of knowledge were given in the field of building antennas - the meaning of my post was such that it is glorious that a man has the willingness and enthusiasm to independently perform the antenna based on any source because he will learn a lot and will expand the circle of hobbyists in this field
  • #15 16476819
    irekr
    Help: 1192
    Rate: 1238
    It should only be mentioned that the Flagship gives MUX8 in VERTICAL POLICY (unlike TVP1 in analogue at 10), the antenna should be installed in the same polarization.
    In the case of CA-RTV6, the antenna must be attached to the side boom (in the center of gravity), the "back" mount is unrealistic for vertical polarization.
  • #16 16512777
    xXMatrixx
    I decided to build a new antenna. Thank you for all the help.
✨ The discussion revolves around optimizing a 30-year-old VHF antenna for improved reception of channel 7 (191.5 MHz) from the RTCN Chorągwica transmitter, located 80 km away. The user seeks advice on enhancing the antenna's gain, considering modifications such as extending the antenna or adding an amplifier. Various responses suggest that the current antenna is poorly assembled and incomplete, with recommendations to refer to specific designs and dimensions for VHF antennas. Users emphasize the importance of proper installation, including vertical polarization for optimal reception. The conversation also highlights the user's initiative to build a new antenna based on gathered knowledge and resources.
