Fiat Ducato 2.5D 1996: Troubleshooting No Low Beam and High Beam - Relay, Switch, and Bulb Issues
Paci2 16263 9
Why do the low and high beams on a Fiat Ducato 2.5D 1996 click the relays and light the dashboard indicator, but the headlights themselves do not turn on?
The headlights did not work because the power supply wiring was faulty: there was no permanent + on the right fender under the hood, the wires were corroded, and someone had also moved the fuse output wires so they were feeding somewhere else instead of the lamps [#16574851] Clicking relays alone is not enough; check for 12 V at relay terminal 30 and for output at terminal 87 to confirm the relay is actually passing power [#16470592] After repairing the wiring and restoring the fuse outputs to the lamps, the lights worked and the topic was closed [#16574851]
  • #1 16467665
    Paci2
    hello i need help. I recently bought a Fiat Ducato 2.5D 1996 car
    I have a problem with it. short or long lights do not shine. When switching the switch short - long and vice versa, you can hear that the relays are working, i.e. they click but no indicator lights up how to turn on the long lights so the switch works for a short time and the light on the meter lights up. Light bulbs are of course good, I am asking you for help.
  • #2 16467771
    wzielonymgaju18
    Help: 32
    Rate: 110
    See if the light switch is OK, check the fuses,
    Do the rear and parking lights work?
  • #3 16469154
    Paci2
    no siemka fuses I checked are all relays are 2 from short to one and from long to the other. I changed them for something else. as if the current from the relays does not go out on the fuses because there is no voltage in the fuses
  • #4 16469160
    marqqv
    Level 32  
    Help: 162
    Rate: 609
    Paci2 wrote:
    the fuses I checked are all relays are 2 from short one and from long second. I changed them for something else
    It remains to look in the installation (bundle) :D
  • #5 16470130
    Paci2
    ok but where and what? switches are good current to the relays comes but I do not see the output on them maybe someone will suggest something because I am a little weak with the electric in the car but I get something
  • #6 16470592
    nikusert
    Help: 699
    Rate: 1755
    Hello .
    If the relays are ticking, check that they have DC power supply at terminal 30 and that there is voltage at their output at terminal 87. There may be relays burnt and hence this effect.
  • #7 16471111
    Paci2
    when it came to relays, the current appeared on them only then when I switched the switch at the steering wheel constant current was not.
    at the moment I do not have a car under the house because I change the engine shells are over next week I will see the relays and write back
  • #8 16471116
    nikusert
    Help: 699
    Rate: 1755
    I am waiting for a response.
    Greetings.
  • #9 16497746
    Paci2
    it will take me a little bit to check the lights because the car was still stalling a bit in the gear ratio
  • Corroded power wire and miswired fuse outputs fixed
    #10 16574851
    Paci2
    Hello, I'm sorry I haven't spoken for so long, I haven't been to Poland. I came to order what is with these lights first there was no permanent plus tarnished wires under the hood on the right fender secondly someone changed the output wires from the fuses and instead of going out the lamps was connected elsewhere. Thanks to nikusert for the hint with relays
    since the lights I did, I consider the topic closed, thanks a lot for your help
The discussion revolves around troubleshooting lighting issues in a 1996 Fiat Ducato 2.5D, specifically the absence of low and high beam functionality. The user reports that while the relays click when the switch is activated, no lights illuminate. Initial suggestions include checking the light switch and fuses, which the user confirms are functional. Further investigation reveals that the relays receive power only when the switch is engaged, indicating potential wiring issues. The user ultimately identifies corroded wires and incorrect connections from the fuses as the root cause, leading to a resolution of the lighting problem.
