Seat Leon 1 - Coding process for 1.9 TDI 2005 model's remote control after battery replacement
sdan99 13767 4
  • #1 16467757
    sdan99
    Hello, I recently purchased a Seat Leon 1 2005 1.9 TDI 5 doors. The remote control in the key did not work, so I opened mechanically all the time, recently I replaced the battery in the remote control, when I press the red LED is lit, but it still does not open or close, I think that the remote control simply decoded. I would like to do it myself at home and save a little, for all help I will be very grateful! :)
  • #2 16467781
    ste
    Help: 184
    Rate: 278
    Programming the remote control in this car rather only by means of a diagnostic computer, e.g. VCDS, VCP and others.
  • #3 16467787
    sdan99
    So it is rather not possible through two keys and button combinations?
    ste
    Help: 184
    Rate: 278
    There is some synchronization procedure used when a given remote control was already programmed for this car and you actually do something with the second key, you can try. You are sure to go out without problems. But this is only synchronization, not programming of the remote control.
  • #5 16468069
    konrad04121993
    Rate: 13
    try this if it goes vcds
