Program Options for Detecting Repeated Words in Long Text: Highlighting Tools & More
michalak92 43209 18
How can I check a long text for repeated words and list or highlight them automatically?
Use a Word VBA macro that scans `ActiveDocument.Words`, counts unique words, and writes the results to a new table with each word and its occurrence count; the posted version also lets you exclude chosen words and sort by frequency [#7096711] To use it in Word 2003, set Macro Security to Medium in Tools/Options/Security, reopen the file, and enable macros when prompted; `Alt+F11` opens the Visual Basic editor if you need to view or paste the code [#7099842] The thread also mentions alternative analyzers such as the online `textalyser.net` and the offline `textanalyzer.blogspot.com` tool [#7096508]
  • #1 7093702
    michalak92
    Help: 7
    Rate: 22
    Is there any program that checks if there are words that repeat in a given text? Ie. I introduce some long text, and it would somehow highlight repeated words, etc.
  • #2 7093715
    fuutro
    Help: 1450
    Rate: 836
    Word has this feature turned on by default.
  • #3 7093738
    michalak92
    Help: 7
    Rate: 22
    Where ? I don't mean the usual repetitions like "I bought a new car yesterday", but repetitive words in different parts of the text.
  • #4 7093859
    sens
    Help: 7
    Rate: 17
    If you want how many times a specific string of characters has occurred, the "change" function and enter the same string of characters you are looking for and the same to change - it will count the number of times it has been changed.
  • #5 7093906
    michalak92
    Help: 7
    Rate: 22
    The point is that I have such a long list of words in Word and I would like to check what words are repeated there (and they certainly are) so as not to unnecessarily print it.
  • #6 7093917
    sens
    Help: 7
    Rate: 17
    How many words are there in the entire text?
    If not much, I will try to write something in VB quickly ... when I find a moment ...
  • #7 7093968
    michalak92
    Help: 7
    Rate: 22
    About 500.
    sens
    Help: 7
    Rate: 17
    It will count and save in a new document :)
    Tested in MSWord 2003
    I hope it will come in handy and that's what it was about :)
    Obviously as in VB in msword
             Dim Slowo As String           'slowo z tekstu - szukane
             Const max_ilo_slow = 9000              'ilosc maksymalna slow ... ograniczenia :(
             Dim Slowa(max_ilo_slow) As String      'tablica z slowami
             Dim Licznik_slowa(max_ilo_slow) As Integer      'tablica z iloscia wystapienia konkretnego slowa
             Dim Unikalne_licznik As Integer             'ilosc slow unikalnych w tekscie
             Dim Sortowanie As Boolean              'sortowanie - po ilosci wystapien
             Dim Ilosc_slow As Long                 'ilosc slow w dokumencie - wszystkie
             Dim Wylaczenia As String             'Slowa ktore wylaczyc z liczenia
             Dim F As Boolean               'flaga pomocnicza
             Dim j, k, l, Temp As Integer       'liczniki itp.
             Dim TmpSlowo As String                ' Tyczasowe slowo
             Wylaczenia = ""
             Wylaczenia = InputBox$("Wpisz słowa które chcesz wyłączyć z przesukiwanego tekstu, słowa umieść w nawiasach [ ].", " Wyłączone słowa", "")
    'poniżej przykład jak wpisać:
    '"[z][i][do][o][w]" itp
             ' pytanie czy sortować po ilości wystąpień
             Sortowanie = True
             Selection.HomeKey Unit:=wdStory
             System.Cursor = wdCursorWait
             Unikalne_licznik = 0
             Ilosc_slow = ActiveDocument.Words.Count
             WSlowa = ActiveDocument.Words.Count
             ' liczymy :)
             For Each aword In ActiveDocument.Words
                 Slowo = Trim(aword)
                 If Slowo < "A" Or Slowo > "z" Then Slowo = ""
                 If InStr(Wylaczenia, "[" & Slowo & "]") Then Slowo = ""
                 If Len(Slowo) > 0 Then
                     F = False
                     For j = 1 To Unikalne_licznik
                         If Slowa(j) = Slowo Then
                             Licznik_slowa(j) = Licznik_slowa(j) + 1
                             F = True
                             Exit For
                         End If
                     Next j
                     If Not F Then
                         Unikalne_licznik = Unikalne_licznik + 1
                         Slowa(Unikalne_licznik) = Slowo
                         Licznik_slowa(Unikalne_licznik) = 1
                     End If
                     If Unikalne_licznik > max_ilo_slow - 1 Then
                         j = MsgBox("W tekście jest więcej unikalnych słów niż podałeś. Zwiększ maksymalną ilość słów", vbOKOnly)
                         Exit For
                     End If
                 End If
                 Ilosc_slow = Ilosc_slow - 1
                 StatusBar = "Pozostało: " & Ilosc_slow & "     Unikalnych: " & Unikalne_licznik
             Next aword
             ' sortowanie
             For j = 1 To Unikalne_licznik - 1
                 k = j
                 For l = j + 1 To Unikalne_licznik
                     If (Not Sortowanie And Slowa(l) < Slowa(k)) Or (Sortowanie And Licznik_slowa(l) > Licznik_slowa(k)) Then k = l
                 Next l
                 If k  j Then
                     TmpSlowo = Slowa(j)
                     Slowa(j) = Slowa(k)
                     Slowa(k) = TmpSlowo
                     Temp = Licznik_slowa(j)
                     Licznik_slowa(j) = Licznik_slowa(k)
                     Licznik_slowa(k) = Temp
                 End If
                 StatusBar = "Sortowanie: " & Unikalne_licznik - j
             Next j
             ' Wyniki w nowy dokument :) i jako tabelke :)
             tmpName = ActiveDocument.AttachedTemplate.FullName
             Documents.Add Template:=tmpName, NewTemplate:=False
             Selection.ParagraphFormat.TabStops.ClearAll
             With Selection
                 .TypeText Text:=Slowa(j) & vbTab & Trim(Str(Licznik_slowa(j))) & vbCrLf
                 Next j
             End With
             ActiveDocument.Range.Select
             Selection.ConvertToTable
             Selection.Collapse wdCollapseStart
             ActiveDocument.Tables(1).Rows.Add BeforeRow:=Selection.Rows(1)
             ActiveDocument.Tables(1).Cell(1, 1).Range.InsertBefore "Słowo"
             ActiveDocument.Tables(1).Cell(1, 2).Range.InsertBefore "Ilość wystąpień"
             ActiveDocument.Tables(1).Range.ParagraphFormat.Alignment = wdAlignParagraphCenter
             ActiveDocument.Tables(1).Cell(ActiveDocument.Tables(1).Rows.Count, 1).Range.InsertBefore "Ilość wszystkich słów w dokumencie"
             ActiveDocument.Tables(1).Cell(ActiveDocument.Tables(1).Rows.Count, 2).Range.InsertBefore WSlowa
             ActiveDocument.Tables(1).Cell(ActiveDocument.Tables(1).Rows.Count, 1).Range.InsertBefore "Ilość unikalnych słów w dokumencie"
             ActiveDocument.Tables(1).Cell(ActiveDocument.Tables(1).Rows.Count, 2).Range.InsertBefore Trim(Str(Unikalne_licznik))
             System.Cursor = wdCursorNormal
         Selection.HomeKey wdStory
  • #10 7096824
    michalak92
    Help: 7
    Rate: 22
    OK thanks. And how to run it in MS Word?
  • #11 7096972
    sens
    Help: 7
    Rate: 17
    I am attaching a file ... just delete the text and paste yours. Press the button and that's it :)
    • test.doc (50.5 KB) You must be logged in to download this attachment.
  • #12 7097078
    michalak92
    Help: 7
    Rate: 22
    I press the button and I start MS Visual Basic (compiler?).
  • #13 7097106
  • #14 7097303
    michalak92
    Help: 7
    Rate: 22
    The thing is, I don't know how to turn them on :D
  • #15 7097329
  • #16 7098313
    michalak92
    Help: 7
    Rate: 22
    I hit alto and F8, and there are no macros in the list. I have MS Word 2003.
  • #17 7099842
    sens
    Help: 7
    Rate: 17
    Options> Security> Macro Security> Select Medium Security.
    When you open the file again, it will ask if you want to enable macros and click enable.
    Left Alt + F11 opens the VisualBasic editor ... because it's not a macro :)
  • #18 7101074
    michalak92
    Help: 7
    Rate: 22
    Thank you very much ! Now it is working.
  • #19 16852355
    3do18
    hey, but it doesn't work in office 2016, doesn't it? nothing is happening to me
✨ The discussion centers around finding programs that can detect and highlight repeated words in long texts. Users inquire about features in Microsoft Word, with one noting that Word has a default feature for detecting repetitions. However, they seek a method to identify repeated words across different sections of a text. Suggestions include using the "change" function in Word to count occurrences of specific strings. Additionally, online tools like Textalyser and offline tools like Text Analyzer are recommended for analyzing text. A user shares a Visual Basic (VB) script that can count and save repeated words in a new document, with instructions on enabling macros in MS Word 2003. Some users express concerns about compatibility with newer versions of Office, such as Office 2016.
