Connecting Chinese Car Radio: Wiring & ISO Harness Guide for No-Name Brands
Martineditt 64800 19
How do I connect the power wires of a Chinese car radio to the car’s ISO harness?
Connect the radio wires by function: red to ACC (switched ignition power), yellow to BATT+ (direct battery power), black to ground, blue to the antenna or antenna amplifier, and orange to illumination if you want that feature [#17126292] Pin A4 should go to BATT+ / the yellow direct battery feed [#17126621] The thread also clarifies that the white plug is the car-side connector and the black plug is the radio-side connector [#17126585]
  • #1 17126182
    Martineditt
    Rate: 27
    Hello. I bought a Chinese no name and I do not know how to connect the wires to the ankle?
    I managed the loudspeakers. The question of electricity remains. In the pictures, an ISO bar and a description of the radio. Thanks for the help.
    Connecting Chinese Car Radio: Wiring & ISO Harness Guide for No-Name Brands1521969761...738742.jpg (600.13 kB)You must be logged in to download this attachment. Connecting Chinese Car Radio: Wiring & ISO Harness Guide for No-Name Brands1521969684...045311.jpg (575.43 kB)You must be logged in to download this attachment. Connecting Chinese Car Radio: Wiring & ISO Harness Guide for No-Name Brands1521969653...140180.jpg (517.38 kB)You must be logged in to download this attachment.
  • #2 17126292
    Pedros050
    Help: 2471
    Rate: 3930
    Hello. Everything described on the cards.
    red - power after the ignition
    yellow - power from aku.
    black mass
    blue - power for the antenna or antenna amplifier
    orange - straining after putting on the lights or because the ignition switch is at your discretion
    and this white bone is from this chinczyk? Because stnndart has it. Connecting Chinese Car Radio: Wiring & ISO Harness Guide for No-Name Brands
  • #3 17126318
    Martineditt
    Rate: 27
    This white cube is out of the car. And I have 5 free wires. Black, red, blue, green, gray. And what now?
    . And in this Chinese there are two black cables one with the description GND And the other GND-. Is it going to be fastened together?
  • #4 17126333
    Pedros050
    Help: 2471
    Rate: 3930
    You're only interested in 15 GND - the rest mass is in the back system.
    Freddy
    Help: 1394
    Rate: 2823
    Yeah, sure, and 16 and 17 who will connect?
    The mass alone is not enough to play, you still need power.
  • #6 17126426
    Martineditt
    Rate: 27
    Gentlemen, I have wires in my ankle: black, red, gray, green, blue. And in Chinese black GND-, second black GND, orange ILL, red ACC, yellow B +, pink AMP, blue ANT-CONT.
    How to connect it with what to play?
  • #7 17126480
    Pedros050
    Help: 2471
    Rate: 3930
    After all, I wrote you in post # 2?
  • #8 17126547
    Martineditt
    Rate: 27
    It's a radio cube
    • Connecting Chinese Car Radio: Wiring & ISO Harness Guide for No-Name Brands 15219790382013556643388464618178.jpg (1.98 MB) You must be logged in to download this attachment.
  • #9 17126558
    Pedros050
    Help: 2471
    Rate: 3930
    And the cube to which you want to connect and in what car?
  • #10 17126561
    Martineditt
    Rate: 27
    This is the cube from the car. Sorry. The car is Honda Prelude IV generation
    I connected something badly because the radio worked ok, the antenna was going out but the parking lights were lost. It fired a fuse from these lights. I got out the radio, changed the fuse and the lights came back.
    Pedros050
    Help: 2471
    Rate: 3930
    Turn this plug from the side to the radio?
  • #12 17126585
    Martineditt
    Rate: 27
    This white plug is from the car and the black plug is for the radio
    • Connecting Chinese Car Radio: Wiring & ISO Harness Guide for No-Name Brands 1521979970413739521823.jpg (934.77 KB) You must be logged in to download this attachment.
    Freddy
    Help: 1394
    Rate: 2823
    So something like that?
  • #14 17126598
    Martineditt
    Rate: 27
    Yes. Exactly the same
    Pedros050
    Help: 2471
    Rate: 3930
    And the matter has already cleared up with connection.
  • #16 17126615
    Martineditt
    Rate: 27
    Ok. A pin a4 where to connect?
    Pedros050
    Help: 2471
    Rate: 3930
    Hold memory for BATT + yellow direct power from aku.
  • #18 17126628
    Martineditt
    Rate: 27
    Ok. Thank you so much for help. I'm going to check. I will let you know what and how
    Added after 43 [minutes]:
    All right. Thank you so much for help ;)
    Freddy
    Help: 1394
    Rate: 2823
    That's OK then.
    Close the topic using the key Connecting Chinese Car Radio: Wiring & ISO Harness Guide for No-Name Brands - you will get extra points for it.
  • #20 17126761
    Martineditt
    Rate: 27
    I would like to thank Fredro and Piterrr for help. Thanks to you everything works as it should.
The discussion revolves around connecting a Chinese no-name car radio, focusing on wiring and the ISO harness. The user initially inquired about the correct wiring connections, specifically for power and ground. Various responses provided detailed wiring color codes: red for ignition power, yellow for battery power, black for ground, blue for antenna power, and orange for illumination. The user faced challenges with multiple black ground wires and experienced issues with blown fuses when connecting the radio. After clarifying the wiring setup and receiving guidance on connecting the power and ground wires, the user successfully resolved the issues and expressed gratitude for the assistance received.
TL;DR: Chinese no‑name radios usually expose 5 key power/aux wires; “red - power after the ignition.” Map ACC/red, BATT+/yellow, GND/black, ANT/blue, ILL/orange to ISO A‑block safely. [Elektroda, Pedros050, post #17126292]
Why it matters: This helps DIY installers connect no‑brand head units without blowing fuses, losing memory, or miswiring.
For: Drivers fitting a Chinese radio to a car’s factory plug and ISO harness.
What do the red, yellow, black, blue, and orange wires do on Chinese no‑name radios?
They are the core power/aux lines. Red is ACC/ignition. Yellow is constant BATT+. Black is chassis ground. Blue feeds a power antenna or antenna amplifier. Orange is illumination for backlight dimming. “red - power after the ignition.” Match these to the ISO A‑block. [Elektroda, Pedros050, post #17126292]
Which wire goes to ISO pin A4 for memory, and why?
Connect the radio’s yellow BATT+ to ISO A4. That constant 12 V keeps presets and the clock alive. If A4 lacks constant power, your radio will lose settings every key cycle. Tie ACC/red to A7 and GND/black to A8. [Elektroda, Pedros050, post #17126621]
My car has a white factory plug and my radio a black ISO plug—how do I connect them?
Use a vehicle‑specific adapter harness that mates the white car plug to a standard ISO plug. Then connect the ISO to your radio lead. This avoids cutting factory wires and keeps features like antenna control intact. [Elektroda, Freddy, post #17126595]
I have two black wires labeled GND and GND-. Should I tie them together?
No. Connect the main GND to chassis ground. Leave the GND‑ or secondary ground as the radio’s internal reference unless the manual instructs otherwise. “You’re only interested in … GND – the rest mass is in the back system.” [Elektroda, Pedros050, post #17126333]
I blew my parking‑light fuse after wiring the radio—what went wrong?
A miswire likely shorted a lighting circuit or mixed the illumination lead. Replace the blown fuse. Disconnect the orange ILL, verify ACC, BATT+, and GND with a multimeter, then reconnect ILL correctly. Re‑test lighting before finalizing. [Elektroda, Martineditt, post #17126561]
How should I connect ANT‑CONT and AMP on this radio?
Use blue ANT‑CONT to drive a power antenna motor or antenna amplifier. Use the AMP/AMP‑CONT (pink on some units) to switch an external amplifier. Do not combine them on one device. Labeling on your unit confirms these roles. [Elektroda, Martineditt, post #17126426]
How can I identify ACC and BATT+ without a diagram?
Use a multimeter.
  1. Set DC volts, black probe to chassis, red to each pin.
  2. Find constant ~12 V (BATT+). It reads 12 V with key off.
  3. Find switched ~12 V (ACC). It reads 0 V off, 12 V in ACC/ON. Tape‑label both leads before connecting. [“Crutchfield: How to install a car stereo”]
Why do my presets reset every time I turn off the car?
The yellow BATT+ is not on a constant 12 V. Move the radio’s yellow wire to a true battery‑hot feed (ISO A4). Keep red on switched ACC (ISO A7). This preserves memory between drives. [Elektroda, Pedros050, post #17126621]
What ISO 10487 pins should I know for power?
Remember the A‑block. A4 is constant BATT+, A7 is ACC/ignition, A8 is ground, A5 is electric antenna/remote. The A and B blocks together provide 16 pins (8 each), covering power and speakers. That layout speeds diagnosis and wiring. [“ISO 10487”]
Can I connect the orange ILL wire to ignition if I don’t need dimming?
Yes. Illumination can tie to the lighting circuit for dimming, or to ignition if you prefer full brightness. If unused, cap it safely. As one expert notes, it’s “at your discretion.” Confirm behavior after dusk. [Elektroda, Pedros050, post #17126292]
Do I need a Honda‑to‑ISO adapter for a Prelude IV?
Yes, use a Honda‑specific harness that plugs into the factory white connector and provides standard leads/ISO. A common example is Metra 70‑1720 for many 1986–2001 Honda models. It enables a clean, reversible install. [“Metra 70-1720”]
What’s the safest connection order to avoid shorts during install?
Prepare first. Disconnect the negative battery terminal. Identify and tape‑label BATT+, ACC, and GND on both sides. Make connections with crimp or solder, then reconnect battery and test. Only then hook antenna, AMP, and ILL leads. [“Crutchfield: Car stereo installation basics”]
