Solar Installation: Cost Calculation for 230V, 2000W Heater in Boiler - Photovoltaic Set Guide
picus113 11634 10
How much does it cost to build a photovoltaic set to power a 230V, 2000W boiler heater?
A 2 kW PV setup for a boiler heater will cost at least several thousand PLN, mainly because the panels are the most expensive part, and you also need a controller/regulator plus cables, mounts, and other hardware [#16470834] Used PV panels were estimated at about 1.5 PLN/W, which gives roughly 3000 PLN just for 2 kW of panels, while a complete 2 kW hot-water setup with used polycrystalline/monocrystalline panels and an MPPT controller was estimated at about 5000 PLN [#16470834][#16471087] One user reported a complete installation with 8 panels, frame, wiring, controller, and heater for 3800 PLN [#16471131] Directly connecting the panels to the heater is not recommended because of mismatch losses, so some kind of controller is needed [#16470834] The answer also suggests checking whether the hot-water demand is only for 1–2 people and whether solar thermal would be a better fit for summer use [#16470834][#16470852]
  • #1 16470781
    picus113
    I warmly welcome,
    Could someone tell me what would be the cost of a photovoltaic set to power a 230V heater some 2000W in a boiler.
    I mean only powering the above heater.
    I don't know how to calculate it :)
    Many thanks in advance for your reply.
  • #2 16470783
    marcinbbb
    Help: 44
    Rate: 178
    And some heater controller something these matters, because you probably do not want smoking connect directly to the heater?
  • #3 16470790
    picus113
    I don't know how to do it best.
    I just want hot water in the summer without smoking in the oven :)
    The CO boiler has an additional 230V heater installed.
    I will be grateful for all hints.
  • #4 16470834
    Xantix
    Help: 686
    Rate: 1657
    First of all, you count the cost of the panels, because it will come out the most expensive. On alledrogo you can find, for example, used PV panels several years old at a price of 1.5 PLN / W - which gives a cost of 3000 PLN for a 2 kW installation. If you wanted new panels, it would probably come out a lot more expensive. Plus some panel regulator (connecting the panels to the heater "rigidly" is not a good idea - you will lose too much energy due to a mismatch) probably a few stacks will also come out. Additionally, general cargo - cables, fasteners, screws, other small items - also accumulates a little penny. In total, I think that a few thousand must be spent on such a thing.
    Although I would count first, are the PV panels really calculating? What is your DHW consumption? How many people use it? Because from what I know, DHW heating with panels is calculated only when consumed by 1-2 people. With greater demand, solar panels or solar panels come out better. Although those for the summer season can also be done easily at home ...
  • #5 16470841
    picus113
    Only 2 people use CWU,
    And what do you mean that you can make solar panels at home ???
  • #6 16470852
    Xantix
    Help: 686
    Rate: 1657
    If the heating of DHW is limited only to the summer season, you can build solar panels from generally available materials, such as:
    https://www.elektroda.pl/rtvforum/topic1412442.html
    There are quite a few topics of this type even on an electrode. People brag that it works for them ...
    Although in your case PV can pay off. On the other hand, the CWU heating system based on PV panels is simpler in construction and easier to use than conventional solar panels.
  • #7 16470906
    retrofood
    Help: 1140
    Rate: 4796
    It's like taking a few old radiators, painting them black so that they better absorb the sun's rays, connecting them all with pipes and exposing them to the sun. Of course, you would have to fill them with water, which the sun will heat and you will consume.
    Of course, this is the principle of operation, such a shortcut.
  • #8 16471087
    anaba255
    Help: 95
    Rate: 262
    In this topic, I described the installation I have at home;
    https://www.elektroda.pl/rtvforum/topic3317504.html
    The cost of installing 2kW for heating hot water on used polycrystalline or monocrystalline panels, dedicated under the frame and MPPT controller, at current prices on the Internet about 5000 PLN.
  • #9 16471131
    Wojte1199
    Level 19  
    Help: 29
    Rate: 96
    Hello The whole installation used panels 8 pcs frame wire driver brizo plus heater 3800 PLN.
  • #10 16471299
    Leon444
    Help: 48
    Rate: 355
    The price depends largely on the panels you buy (what power) ...
    If you want to get into it, think about better panels to later extend them with similar power ...
    And believe me :) it's addicting :) I started with 2kW and now I have 9kW ... :)
  • #11 16471384
    JESIOTR1
    Help: 64
    Rate: 441
    picus113 wrote:
    to power a 230V heater with some 2000W in the boiler.
    Do not be so greedy to power (top up) the 2000 W heater may be less power.
    I suggest a hybrid: solar farm + wind farm because sometimes when there is no sun (at night and in winter) a strong wind blows and vice versa.
    There is no need to adjust because the set thermostat in the boiler will turn off the main power supply from the network and in the first place will operate renewable energy - free.
The discussion revolves around the cost calculation for a photovoltaic (PV) system to power a 230V, 2000W heater in a boiler. Users suggest that the primary expense will be the PV panels, with prices for used panels around 1.5 PLN/W, totaling approximately 3000 PLN for a 2 kW installation. Additional costs include a panel regulator, cables, and other installation materials, leading to an estimated total of several thousand PLN. The feasibility of using solar panels for domestic hot water (DHW) heating is debated, with suggestions for simpler PV systems over traditional solar panels. Some users share personal experiences and costs related to their installations, emphasizing the potential for DIY solar panel construction. The conversation also touches on hybrid systems combining solar and wind energy for more reliable power supply.
