270W Solar Panel & 24V Heater for 50-Liter Boiler: Achieving 30°C Water Temp in Summer
lisos 9276 13
  • #1 17546999
    lisos
    Help: 21
    Rate: 98
    I have a 50-liter boiler and I would like to have at least lukewarm water in the summer, i.e. about 30 degrees. How do I buy a 270W panel and a 24V heater and nothing more, no inverter is a chance? The panel can give a voltage of up to 36V, after connecting the heater it will drop to about 24V, the heater 300W? These are my first theoretical considerations about panels.
  • #2 17547047
    Krzysztof Kamienski
    Help: 2032
    Rate: 5155
    @lisos Count the efficiency! Why not a collector, even your own design?
  • #3 17547049
    fuutro
    Help: 1450
    Rate: 836
    According to this, you can combine a Step-down (buck) lowering converter that will give a good voltage for the heater.
  • #4 17547067
    Krzysztof Kamienski
    Help: 2032
    Rate: 5155
    fuutro wrote:
    Accordingly, you can combine a Step-down (buck) converter, which will give a good voltage for the heater.
    See post # 2 - fitness :cry: And a small matter - the solar collector absorbs the infrared spectrum, so its efficiency on cloudy days will also be higher than that of photovoltaics (comparatively).
  • #5 17547591
    lisos
    Help: 21
    Rate: 98
    The collector falls off, I would prefer the panel without a converter (simplicity of construction, smaller losses) but will these assumptions pass the exam?
  • #6 17547614
    gaz4
    Help: 77
    Rate: 2947
    Take a look at my topic about the boiler, PV and two heaters, there is almost everything about direct connection. The proposed system will not work because a 300W / 24V heater has a resistance of about 2?. The 24V panel works most efficiently at Umpp around 30V, i.e. with such a heater, the power should be:
    30 * 30/2 = 450W
    Since PV will have 270W, it will give even on sunny days only half the energy it can produce . Not to mention other problems like the risk of burn-out of a 24V heater connected to a 24V PV (actually> 30V).
    To have lukewarm (> 30 degrees) water in a 50l bolyler in the summer you need to warm it by about 15 degrees or deliver about 1 kWh per day. If you make a layout with a well-fitted 270W panel, you have
  • #8 17557196
    Kwazor
    Help: 184
    Rate: 529
    It is GAZ4 instead of combining like a horse uphill and packing an additional panel (which works inefficiently for this), you need to use the MPPT regulator for the heaters and it will squeeze out of the panel or panels as much as possible. (especially when the weather is worse)
    Example: The heater has the same parameters as the panel panel = ok super 100% power flies.
    Sweet 50%
    Power on the heater: 25%
    Because the load resistance is the same and the source has 2 times greater internal resistance.
    power curve not 45 degrees only 78 degrees ... so wears even higher
    Such an example in the photo
    And here is a very mismatched panel power / heater power and voltage:
    4XGS50 panels (43V Vmpp actually have less) = 200W
    Heater 12V 300W
    As you can see, the system adjusts the heater resistance to the resistance of the panels at their optimal operating point and the system works with maximum possible efficiency from morning to evening.
    And there is no risk of damaging the heater (even if the power of the panels = 300W).
    Half measures are not a solution, okay, "a little" works, but I would not be satisfied with this.
    That is why this regulator was created and if you do not need hot water, it charges the 12V batteries. A 2-in-1 that makes sense.
  • #9 17558535
    gaz4
    Help: 77
    Rate: 2947
    Kwazor wrote:
    instead of combining like a horse uphill and packing an additional panel (which works inefficiently) you need to use the MPPT heater controller and it will squeeze out of the panel or panels as much as possible. (especially when the weather is bad)
    Have you read about the economic aspect of such a procedure? Even the new CIGS calculates more than MPPT. But this is not the end of possibilities because I prefer amorphous ones that are much cheaper (a few years ago I bought new ones for just over PLN 1 / W). I have a very large roof, even if I used low-yielding amorphous I would put over 5 kW on it, if I wash it x2 ;) Do they work inefficiently? For most of the year, 70-80% of Umpp voltage remains on them, i.e. they operate with such efficiency. Sometimes in summer Umpp is exceeded, very rarely the voltage drops below 50%. But only when it is dark even during the day, i.e. sunshine is about 50W / m2. Then from 1 kW you can collect max. 50W, after subtracting the energy consumed by MPPT for heaters, a few watts remain. I doubt that my primitive driver (I've been using it for over a year: https://www.elektroda.pl/rtvforum/topic3223621-90.html#16575602) would have worse effects then. MPPT has an advantage over the heater switch in a narrow range: approx. 100-200 W / m2 and full sunlight when the water in the boiler is cold because it can 100% use it. However, sometimes it is a typical turtle race with a hare: a perfectly matched MPPT will heat the boiler in 5h and turn off, and a switch based on relays in 10h and in the evening we have the same effect in the form of the same hot water in the tap :)
  • #10 17563054
    dzibus1
    Rate: 11
    @ gaz4 exactly. How I bought off-grid stimulants. They have less efficiency than poly or mono, but they work all year and I have always cut off something.
  • #11 19002275
    ufobb
    Is anyone able to point out a ready-made solution to my problem?
    I plan to install a photovoltaic panel of approx. 300W, which is to power the charging of the 12V battery in the first place, approx. 100 Ah, and when the battery is 100% charged, the rest of the PV energy would heat the water in the 10L boiler, heater 300W, voltage 230V. I would not like the boiler to be heated from the battery after sunset (for me, the priority is to have electricity, not hot water - hot water is to be an addition, if the weather permits it). Thanks in advance for your help j
  • #12 19003398
    gaz4
    Help: 77
    Rate: 2947
    I will not give you the ready one, but I will tell you how to do something like that. Perhaps a PWM controller for the boiler is enough and that's it. Its task is to maintain high heating efficiency, which is equivalent to a constant voltage on PV. If it does not interfere with the operation of the charger, that's enough. So for PV we connect the charger and PWM in parallel, and the rest will be taken care of by physics ;)
  • #13 19003884
    ufobb
    Thanks for showing interest ;)
    I do not really understand how such a solution is supposed to work, the heater's rated voltage is 230V, and the PV operating voltage is about 32V (I mean PV Model: SR320-60M). Is PWM able to meet such needs? Besides, will the PWM and the charger not "fight" with each other in such a connection system?
    gaz4 would you be kind enough and would you like to help and explain it in more detail? I would be obliged :D
  • #14 19004731
    gaz4
    Help: 77
    Rate: 2947
    PWM works on the principle that the heater gives "peaks" with a voltage of 230V, so there is no loss. The lower the PV voltage, the shorter these "peaks" are, at 32V the fill will be several%. Looking from the PV side, a good PWM should keep the voltage close to the maximum power point. If a charger is connected in parallel with PWM to PV, it will load the panels. Then a good PWM will consider that the power supplied by the PV has decreased and will reduce the filling of the voltage "peaks" supplied to the heater. As the battery is charged, the PV load from this side will decrease so the PWM will increase the duty cycle. This is probably the simplest description I can provide :)
    Practical problems that may arise are poor holding of the point of power. Then the parallel connection of the battery regulator may cause some losses because the voltage will be too low. Another is the fact that PWMs "sow" which may disrupt the regulator's operation. But when the cables are shortened (especially those connecting the PWM with the heater) and if necessary, add a choke and a larger capacitor in the battery regulator, the problem of mutual interference should not occur.
✨ The discussion revolves around the feasibility of using a 270W solar panel to heat a 50-liter boiler to approximately 30°C during summer using a 24V heater. Participants debate the efficiency of direct connections versus using converters, with suggestions for using a step-down (buck) converter to optimize voltage for the heater. Concerns are raised about the insufficient power output from the panel to meet the heater's requirements, particularly under varying sunlight conditions. The importance of matching the panel and heater specifications is emphasized, with recommendations for using MPPT (Maximum Power Point Tracking) regulators to enhance efficiency. Additionally, alternative solutions involving PWM (Pulse Width Modulation) controllers are discussed for managing the heating process without compromising the battery charging priority.
TL;DR: For a 50‑L boiler, ~1 kWh/day raises water ~15°C; a 270 W + 24 V/300 W direct link delivers "only half the energy it can produce." [Elektroda, gaz4, post #17556434]
Why it matters: DIYers wanting lukewarm water from PV without an inverter can avoid common sizing, wiring, and controller mistakes.
Will a 270 W PV panel directly drive a 24 V/300 W heater to get ~30°C water in a 50 L boiler?
Not efficiently or safely. A 24 V/300 W heater is ~2 Ω. At a panel’s ~30 V Umpp, that load needs ~450 W, so a 270 W module delivers about half the possible energy. There’s also a burn‑out risk because PV open‑circuit exceeds 30 V. [Elektroda, gaz4, post #17556434]
How much energy do I need to raise 50 L of water by ~15°C in summer?
About 1 kWh per day. That gets typical tap water from cool to lukewarm (~30°C) in a 50‑liter tank. Size your PV and controls to meet or exceed that daily energy, accounting for weather and mismatch losses. [Elektroda, gaz4, post #17556434]
Why does a 24 V/300 W heater waste PV power on a ~30 V Umpp panel?
Because the resistance is mismatched. A ~2 Ω heater at 30 V demands 450 W (V²/R). Your 270 W panel cannot supply that, so it runs off‑MPP and leaves energy unused. "Only half the energy" is a typical outcome here. [Elektroda, gaz4, post #17556434]
Is direct PV-to-heater safe for a 24 V element on a 24–36 V panel?
No. A 24 V element on a panel that reaches >30 V risks over‑voltage and thermal damage. Even if it warms water, it operates off‑MPP and can overheat the element during bright sun or no‑load conditions. Use control or correct element rating. [Elektroda, gaz4, post #17556434]
Should I use an MPPT heater controller instead of adding more panels?
Yes when you want maximum output from limited PV area. An MPPT heater controller matches heater load to panel MPP and adapts to clouds. “It will squeeze out of the panel ... as much as possible.” Many also switch to 12 V battery charging when hot water isn’t needed. [Elektroda, Kwazor, post #17557196]
Can a PWM controller run a 230 V/300 W heater from a ~32 V panel while charging a 12 V battery?
Yes. PWM drives the heater with brief 230 V “peaks,” adjusting duty cycle so PV stays near MPP. Connect the battery charger in parallel with PWM at the panel. As charging load changes, PWM adapts heater duty to use available PV power first. [Elektroda, gaz4, post #19004731]
How do I wire PV, PWM, and a charger so the battery gets priority, then water heating?
Parallel the charger and PWM on the PV terminals. PWM output goes only to the heater. The PWM’s job is to hold near‑constant PV voltage for efficiency; “the rest will be taken care of by physics.”
  1. PV +/− to charger IN and PWM IN in parallel.
  2. PWM OUT to heater.
  3. Set PWM to hold PV near its optimal voltage. [Elektroda, gaz4, post #19003398]
Will a buck (step‑down) converter help match the heater to the panel?
It can set a suitable heater voltage. A step‑down (buck) converter between panel and element lets you lower voltage under bright sun. However, without proper MPP control, efficiency gains may be limited versus dedicated heater controllers. [Elektroda, fuutro, post #17547049]
What happens in weak sun or heavy clouds?
Output collapses. At ~50 W/m², 1 kW of PV gives about 50 W. After controller overhead, “a few watts remain.” In such conditions, simple switching can finish heating later, matching MPPT by day’s end in some cases, despite slower midday heating. [Elektroda, gaz4, post #17558535]
Are solar thermal collectors better on cloudy days than PV-to-heat?
Often yes. Thermal collectors absorb more of the infrared spectrum, so their cloudy‑day efficiency can beat photovoltaics. If your aim is only hot water, a collector can be simpler and yield more in poor light than PV direct‑heat setups. [Elektroda, Krzysztof Kamienski, post #17547067]
Is PV-to-heat financially sensible, and when?
It makes sense with cheap panels and a good mounting slope. One rule given is panels under ~0.5 PLN/W and ready structure. Without low module cost or good geometry, PV‑to‑heat loses on economics compared with alternatives. [Elektroda, Anonymous, post #17547614]
Can adding more cheap panels beat buying an MPPT controller?
Often, yes. Using low‑cost CIGS or amorphous modules can outperform controller ROI. "For most of the year, 70–80% of Umpp voltage remains on them," so simple switching still captures much of available energy without MPPT expense. [Elektroda, gaz4, post #17558535]
Do amorphous or CIGS panels work well for off‑grid water heating?
They can. Large roof areas with amorphous panels can deliver steady voltage near MPP much of the year. This helps simple switch or PWM control perform acceptably without complex MPPT, with more surface area compensating lower module efficiency. [Elektroda, gaz4, post #17558535]
Can a controller handle mismatched heater and panel voltages?
Yes. Example: four GS50 panels (~43 V Vmpp each, 200 W total) driving a 12 V/300 W heater. A dedicated regulator adjusted effective heater resistance to panel MPP and ran efficiently from morning to evening. [Elektroda, Kwazor, post #17557196]
I only want hot water as a bonus—battery must stay priority. What’s the simplest control?
A PWM heater controller in parallel with the battery charger works. The charger loads PV first, and PWM reduces heater duty until extra power appears. This maintains PV near its efficient operating point with minimal parts. [Elektroda, gaz4, post #19003398]
Any EMI issues with PWM, and how do I fix them?
PWM can emit interference that disrupts chargers. Keep PWM‑to‑heater leads short. If needed, add a choke and larger capacitor at the charger input. These measures reduce switching noise and stabilize charging behavior. [Elektroda, gaz4, post #19004731]
