Induction Samsung CTN264EA01 - H is displayed on the diagonal fields
darek1632 7152 2
  • Persistent H display remains despite sensor replacement
    #1 16472133
    darek1632
    Help: 10
    Rate: 24
    Hello, as the topic Samsung CTN264EA01 induction hob displays the letters H. Normally they should light up if the field is hot and burn on two diagonal fields all the time. Everything is OK, but I would like it to work normally. I disconnected the sensor and the same. I exchanged the sensor for another (functional) also did not help. I wonder if something can be set in the controller, but I have no knowledge about it.
    Best regards.
    Barthezz1976
    Level 19  
    Help: 24
    Rate: 164
    So what is the problem further to look for the defect? Without a sensor, it should trigger a "This" error as I remember correctly.
    Upload photos from both sides and mark which sensor is not working properly.
    Isn't it sometimes the album you made lately at the turn of the year?
  • Lower right sensor fault clears H display
    #3 16478868
    darek1632
    Help: 10
    Rate: 24
    OK, I checked some. The stove always lights H in the lower right field and upper left burner from the beginning of connection to the network. Sensor resistance about 8.5k? as well as other functional ones. If I disconnect the bottom right field sensor, it does not throw an error. The letter H disappears. However, if I disconnect the upper left sensor and H is burning all the time, it also does not throw an error. I measured transitions and they reach the controller.
    best regards
    PS.
    This is another Samsung model being repaired
