Deciphering SE 5E and LE Error Codes on Samsung Induction Hob CTN464KC01 Post-Teristor Replacement
Roman4031 51387 4
  • #1 16102117
    Roman4031
    Rate: 18
    Samsung induction model CTN464KC01 after replacing the teristors because it made a short circuit. After starting it shows pot not accepted and LE error. If I hold down the start button, it shows the SE (5E) error. Does anyone know what this means and how to fix it? Thank you very much.
    mrhari
    Help: 835
    Rate: 3239
    LE - too low voltage. The 12V line is less than 9V.
    SE - too long time, more than 10 seconds pressed.
  • #5 16272470
    Roman4031
    Rate: 18
    It turned out that the plugs from the heating zone were changed. after proper connection, the stove fired.
