ITAN ORANGE cable is broken. Has anybody made anybody here with a man?
klusynek 25014 11
Can Orange charge me for repairing a telecommunication cable I damaged during excavation, and can I contest liability if the cable was laid too shallow and without warning tape or an easement?
You will likely be billed for the repair unless you can show the cable was installed improperly, but if the line is not in accordance with the regulations you should not agree to pay automatically. Before digging, utilities should be located with transverse test pits, and if the cable was only about 40 cm deep or had no warning foil, that is strong grounds to dispute liability and document the scene with photos [#16472791][#16472875][#16472888] If you refuse to sign an acknowledgment of fault, the operator may call the police to make a note and then pursue the matter in court [#16472843] One reply also notes that large repair bills can happen, but insured contractors may have coverage [#16472843][#16475694] Another suggests writing to the operator and consulting a lawyer about the lack of easement or registry entry, but the practical advice in the thread is to document the improper installation first [#16475564]
  • #1 16472707
    klusynek
    Hello. Today, during excavation work on the construction site, I picked up the excavator with two 4-core teleinformation cables from Orange. Unfortunately, the cable is on the land development plan, although at a depth of about 40 cm without any protection or warning tape. I called them, it was reported. I immediately asked the consultant who would pay for it, the answer was Orange that I would not pay anything. Nice surprise but OK. After some time, the fitter calls me and asks where it happened and how and that Orange will probably invoice me for it. But after a short conversation, we talked to him that he would come to me on the plot, connect, take PLN 200 and withdraw the application. Well, the questions that arise for me:
    1. Would I really be charged with the costs of such repair, would the whole procedure and God know what it would cost?
    2. As the owner of the plot, I never signed an easement agreement with Orange or TPSA, the previous owner did the same. Despite this, the cables run through my plot half a meter behind my fence. Is it worth sending a letter to them to explain which law there are in the absence of any document or entry in the land and mortgage register?
  • #2 16472775
  • #3 16472791
    opornik7
    Electrician specialist
    Help: 316
    Rate: 1569
    For earthworks, the basic principle is to make transverse probes to accurately locate the existing utilities. What about the fact that at the stage of building the cable was correctly laid out, since over the years someone has collected, for example, 30 cm of earth. Sorry, but unfortunately you will have to bear the repair costs. I do not investigate whether it is an official or unofficial route.
  • #4 16472815
    Włodzimierz Wojtiuk
    Level 32  
    Help: 231
    Rate: 273
    opornik7 wrote:
    if, over the years, someone has collected, for example, 30 cm of land.
    You divulged it.
    Cable too shallow and without tape!
  • Orange cable damage may trigger invoices, police, and insurance claims
    #5 16472843
    Jawi_P
    Level 36  
    Help: 260
    Rate: 715
    I have dealt with such cases more than once. You would get an invoice. Normally you sign a document that you are guilty of breaking etc. The cable was on the plans so you would not run away from it. If you do not want to sign it, the police are called to make a note and the case lands in court.
    But, sometimes it's just like when there's a piercing and 4-wire cable, this thing gets twisted.
    Because the fitter does not want to play the popierdołki, which he does 20 minutes, unless you called the helpline and accepted the damaged / vandalism :) Only that it also depends on the Orange employee "supervisor" technical partner, because Orange alone does not have fitters. Everything in outsourcing.
    I say yes, you would tell the fitter that you would give 100 or 50 PLN and he would do it. Otherwise, he would do it on behalf of Orange and get "nothing".
    And most importantly, very often I met with the fact that a larger contractor is insured against such cases. Only the bigger ones can break the entire sewerage, fiber optics inside, cables for 1000 pairs and wells to sink, etc. Costs? About 10,000 and better.
  • #6 16472847
    opornik7
    Help: 316
    Rate: 1569
    Włodzimierz Wojtiuk wrote:
    You divulged it.
    I did not bode anything ;) Simply by doing projects and cost estimates, I ALWAYS take into account the performance of the probes even when, for example, water, gas or sewage on the map is drawn 2m from my pole. Life has taught me that theory very often misses practice.
  • Refusing liability for improperly installed cables without warning tape
    #7 16472875
    masonry
    Level 30  
    Help: 106
    Rate: 832
    From my own experience (and I made a bit of this crap) I will say that if a given medium is not in accordance with the regulations, I will never pay for breaking it.
    If it is at the wrong depth or there is no warning film, or (very common) the film lies directly on the cable or pipe, I never agree to pay for the damage.
    I always do an exact photographic documentation of the place of the incident with the application of the scoop, and I do not agree to the burden even though I have bought OC.
  • Documenting noncompliant cable installations to contest damage claims
    #8 16472888
    elpapiotr
    Help: 1015
    Rate: 3532
    And that is, I think, the right approach.
    Let everyone do it according to art, there will be no ambiguity.
  • #9 16475564
    jaszczur1111
    Help: 173
    Rate: 494
    Such cables usually lie deeper, about 80-120 cm. And the warning foil is often buried with the cable. Personally, I once participated in such a burial but I had nothing to talk about. For my statement that as the excavator operator will dig up the foil, it will be shrugged on the cable and that's it. Plans are on paper and life is life. The dig has crossed the road several times because it fell out in huge trees. The intersections of the road were marked with concrete pillars. Today there is no trace of them and the cable is. How is a professional team digging this copy to 120. How to take random people for 5 PLN / m of digging is a copy of 40. That's what the TPS once did. I do not know what are the rates today and whether there are any companies renting people with shovels, but it was still 15 years ago.
    Write a letter and tell them to take or pay for the lease. Contact the lawyer first. A friend won the cash for heating pipes.
  • #10 16475694
    funak
    Help: 101
    Rate: 461
    Well, let me tell you a real-life case. From that year.
    Damaged optical fiber during earthworks - new surface. It turned out that connection welding is not possible due to existing connections on the route and new connection is not possible. Effect: replacement of 1200 meters of optical fiber to the nearest connection. Invoice PLN 150,000. Fortunately for the company that she had insurance. And the insurer covered the costs.
  • #11 16475730
    opornik7
    Help: 316
    Rate: 1569
    Do you need to make transverse probes before digging?
    The company has not paid, but it will increase for the next year.
  • #12 16475832
    zbich70
    Help: 1171
    Rate: 6668
    It's good that the SN cable did not plow.
    At least no one was killed.
During excavation work, a user accidentally damaged two 4-core telecommunication cables belonging to Orange, which were buried at an insufficient depth without protective measures. The user inquired about potential costs for repairs and the implications of not having signed an easement agreement with Orange. Responses indicated that the user might be liable for repair costs due to the cables being on the land development plan, despite their improper installation. Many contributors emphasized the importance of conducting thorough utility location checks before excavation and noted that if cables are not buried according to regulations, the user may contest liability. Some shared experiences of significant repair costs incurred from similar incidents, highlighting the necessity of insurance for contractors.
