For 5 hours it picks up to 6 liters. Should there be a non-return valve behind the water meter (the current one is 14 years old) and its possible replacement will solve the problem? The flush valve is turned off so this is not a leak. If, apart from the cistern, I also turn off the water supply to the boiler, the water meter does not fill. For two hours, the water meter did not even move. With unscrewed cistern and boiler valves, when a neighbor from above draws water and turns it off after 10 seconds, the water meter turns on.
stachu12q
stachu12q
