Audi A6 C5 1.8T AWT Engine: Wiring Diagram for Oil Level Sensor to Meter
konrad2k9 8871 2
  • #1 16473173
    konrad2k9
    Help: 5
    Rate: 45
    Audi a6 C5 1.8T engine code AWT counter half fis. Does anyone have a wiring diagram from the oil level sensor to the meter?
    Best regards.
    Oil sensor wiring: meter pin 15 to sensor pin 3
    #2 16473818
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    Only one wire goes from the sensor to the meter - a signal about the oil level and its temperature.
    Green plug pin 15 of the meter is connected to pin 3 of the sensor plug,
    Pin 1 of the sensor plug is a plus after the ignition, pin 2 is ground, 3 is a signal.
    In the attachment, a description of the pins is 1 and 2 and 3 if you don't want to look for it.
    I would like to thank my colleague UCY 7400 for pointing out the error.
    I actually made a mistake when typing it was supposed to be PIN 15.
    • wtyczka.rar (36.29 KB) You must be logged in to download this attachment.
  • #3 16473825
    UCY 7400
    Help: 37
    Rate: 75
    A small correction, the signal from the sensor to the meter goes to pin 15 of the green plug
