Fitkraft Twin Motion Electric Skateboard - Battery Charging Issue, Flashing Battery Symbol
kołti 47592 6
  • #1 16473297
    kołti
    Rate: 16
    I have Fitkraft Twin Motion electric skateboard. After inserting the cable from the charger, the skateboard does not charge. Only the battery symbol on the skateboard flashes.
    What can this be a problem with?
    Greetings.
  • #2 16473299
    szymon122
    Help: 302
    Rate: 762
    With a skateboard or charger ;)
    What answer do you want to get from us? Give back to the service and after the problem.
  • #3 16473320
    kołti
    Rate: 16
    It is probably obvious that either the board or the charger.
    Such that someone may have had a similar problem and would have an idea.
    Maybe it is something simple and you do not have to give it to the site immediately, I think this is a forum to ask.
    ps
    efficient charger, tested with a meter.
  • #4 17370548
    do_tyk
    Rate: 82
    The battery has dropped to a very low voltage state that the charger does not want to recharge. You would have to undress it and check on aku what voltage you have and lift the stabilized power supply until the charger starts charging itself
  • #5 17371090
    Szyszkownik Kilkujadek
    Level 37  
    Help: 211
    Rate: 1014
    Only to do this you need to have some basics of electronics. Well, we can count on the possibility of losing the warranty.
  • #6 17373680
    do_tyk
    Rate: 82
    Yes it's true
  • #7 17378756
    mbrajer
    Rate: 20
    I suspect that the battery has been unloaded for a long time after being discharged. The battery voltage has dropped below the cut-off level (26V). It will not help to get into the battery. It is necessary to dismantle the battery pack and omit the battery driver (combined with the cell package) and recharge the cells (while maintaining current, voltage and temperature control) so that the voltage of discharged cells will rise above 26V. However, the capacity of the recovered battery will be much lower due to wear and critical discharges
    Added after 5 [minutes]:
    Have such a stupid response to your friend. You are unnecessarily discouraging to ask questions and do not provide any substantive content.
The discussion revolves around a battery charging issue with the Fitkraft Twin Motion electric skateboard, where the user reports that the skateboard does not charge and only a flashing battery symbol is displayed. Responses suggest that the problem may stem from either the skateboard or the charger. One response indicates that the battery may have dropped to a very low voltage state, preventing the charger from initiating a charge. It is recommended to check the battery voltage and potentially recharge the cells manually, although this requires basic electronics knowledge and may void the warranty. Concerns about the battery being discharged for an extended period and the risks of critical discharges are also mentioned.
