E-cigarette Battery Issue: FooF Battery Not Charging, Green Light Instead of Red
Szymexx123 27564 7
  • #1 14007398
    Szymexx123
    Hi, I have a problem with charging the battery, when I turn on the charger, the battery flashes a few times but the light on the charger is still green and it should be red. I will add that it is the FooF battery, other batteries are charging normally and I was charging another FooF that is charging normally: /
  • #2 14007418
    oldking
    Help: 162
    Rate: 524
    You answered yourself, since the other batteries are charging, this one is defective.
  • #3 14007427
    problem.z.ko
    Help: 45
    Rate: 44
    You answered yourself.
    Are you sure there is good contact between the battery and the charger?
    Added after 13 [seconds]:
    @posts are covered.
  • #4 14007477
    Szymexx123
    I think so, but I don't know why this one is not charging ... it flashes a few times after plugging in>. <
    If I unplug the battery, it gives signs of life that it is discharged: /
  • #5 14008299
    problem.z.ko
    Help: 45
    Rate: 44
    oldking wrote:
    You answered yourself, since the other batteries are out they land this one is broken.
    Since when can batteries "land"?
    If you have a different battery, put it on and that's it. Put the other one in the appropriate container.
  • #6 14009021
    Szymexx123
    Or is it a short circuit? ; P
  • #7 14009298
    naciamen
    Help: 10
    Rate: 93
    If the short circuit is only to the container you are left.
    I have already thrown two of them because of the short circuit, this button with the electronics is very sensitive, the short circuit lasted maybe 0.5 seconds because of my own stupidity; /
  • #8 14010769
    karolark
    Help: 702
    Rate: 2517
    And since when is the battery non-rechargeable?
    Measurement of voltage and I while charging should dispel any doubts :-)
The discussion revolves around a charging issue with a FooF e-cigarette battery, which fails to charge properly, indicated by a persistent green light on the charger instead of the expected red. Users suggest that the battery may be defective since other batteries charge normally. There are inquiries about the contact between the battery and charger, and concerns about potential short circuits affecting the battery's functionality. One user mentions having previously discarded batteries due to short circuits, emphasizing the sensitivity of the battery's electronics. Suggestions include measuring the battery's voltage to confirm its condition.
