Volkswagen golf 4 1.4 16v - The starter is not turned, the lights are on
maaciius 6972 2
  • #1 17113222
    maaciius
    Hello, I have a problem, my girlfriend went to school 100 km from her place of residence and I know what happened only on her part, she started the car, she drove 20 meters, the car went out after turning the key again, the lights were on, but the starter did not start, it was not possible to fire it or for pride, neither for cables and the question of what could have happened because I do not know whether to borrow a tow truck and download it, can it be a problem with the battery or alternator? Please help
    Moderated By CameR:
    Reg. 3.1.15. Do not ask immediately on the forum if you have not checked anything yourself or have not attempted a self-diagnosis. Remember that advice is provided remotely in the absence of physical access to the device, the problem must be very well described and understood by users.
  • #2 17113237
    CameR
    Moderator of Vehicle Security
    Help: 1139
    Rate: 3272
    maaciius wrote:
    she started the car she drove 20 meters her car went out
    ... Anti-hijacking system installed, key switch failure, no fuel, ...
    maaciius wrote:
    after turning the key again, the lights were on, but the starter did not turn, it was impossible to start it or to be proud
    ... Damaged old forgotten anti-theft protection, damaged ignition block, blown ECU fuse, ECU fault, electrical system fault, ...
    maaciius wrote:
    It was impossible to ignite it, neither for pride nor for cables
    maaciius wrote:
    can this be a problem with the battery or alternator?
    Probably not - apparently the lights come on only "the starter does not spin" ...
    The problem is that it went out when driving after 20s - so it's not the starter fault.
    Necessary diagnostics and preliminary measurements of supply voltages, ground, fuses, ...
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • #3 17113399
    marekwodniak
    Help: 14
    Rate: 194
    Too far for a tow truck, look for a garage nearby, unless it has a policy.
