Max Current Draw from AA Rechargeable Batteries for Remote Control Car
wojcieh007 7224 9
How much current can I safely draw from AA rechargeable batteries in a remote control car without damaging them?
There is no single safe maximum current for all AA rechargeable batteries; it depends on the specific cell, and ordinary AA cells will not withstand continuous 8 A load. [#16477042][#16477108] In general, you can draw current according to the cell’s capacity and datasheet limits, as long as you do not exceed the short-circuit current and you do not discharge below the recommended voltage. [#16477042] One example given was a GP 2700AAHC AA cell rated for “high rate discharge” at 7.5 A, which may be enough for your car. [#16477300]
  • #1 16476987
    wojcieh007
    Rate: 36
    I want to assemble a battery for a remote control car based on AA rechargeable batteries.
    And I have a dilemma. What is the maximum current that can be drawn from such batteries so that they do not get damaged?
  • #2 16476991
    Barton-wlkp
    Help: 26
    Rate: 90
    Isn't it better to think about secured 18650 cells?
  • #3 16477042
    viayner
    Help: 1563
    Rate: 2052
    theoretically, you can take any current (depending on capacity) as long as you do not exceed the short-circuit current and you do not discharge the battery below the recommended voltage. 18650 cells, as the colleague mentioned above, will be more useful here.
    For example, see http://data.energizer.com/pdfs/nh12.pdf
  • #4 16477054
    wojcieh007
    Rate: 36
    I thought about it, but the original battery is 9.6V and it has 8 AA rechargeable batteries.
    In turn, the 18650 cells are 7.2V or 10.8V (and even 12.6V when fully charged), which is nothing like that.
    The car can download up to 8A, which is not enough. I was thinking about Eneloop white batteries, but will such electricity be dangerous for them?
  • #5 16477072
    1 PAWEL
    Help: 674
    Rate: 1364
    wojcieh007 wrote:
    but the original battery is 9.6V and that's 8 AA rechargeable batteries
    A fully charged 8xAA battery will get a voltage of 9.6V.
    3S package 11.1V charged cells to 4.2V will get 12.6V better not to pass
    on LiPo 11.1V, and install for PLN 10 cut-off, low voltage alarm.
    For example, the 11.1V 3S 1800mAh 20C / 30C package
  • #6 16477077
    wojcieh007
    Rate: 36
    Original battery stops charging at 9.8V. I don't know if the voltage around 12V will not damage the car.
    The 3S package is another expense, and that misses the point. AA or 18650 rechargeable batteries are more universal.
  • #7 16477095
    1 PAWEL
    Help: 674
    Rate: 1364
    18650 You will.
    This can switch to LiPo 2S 7.4V after charging 8.4V.
    You have large C current efficiency values on the LiPo pack.
  • #8 16477104
    wojcieh007
    Rate: 36
    I don't want to switch to any non-standard batteries. Buying a 2S or 3S is the same as buying a second original battery.
    AA or 18650 rechargeable batteries can be used for many other things. They get bored with the fun of the model, the rechargeable batteries go to the toy, camera, power bank, etc.
    But will 8A current not be a killer for AA?
  • #10 16477300
    krzysiek_krm
    Level 40  
    Help: 716
    Rate: 599
    for example these:
    http://www.tme.eu/pl/details/accu-r6_2700-hg/akumulatory/gp/270aahc/
    from documentation:
    http://www.tme.eu/pl/Document/bcb579e2ef265f1c9645d398190b99cb/GP270AAHC.pdf
    shows that they have "high rate discharge" 7.5 A, with poverty may be enough.
    Added after 13 [minutes]:
    Alternatively, consider using LiFePo4 cells, they have a lower voltage than LiIon, a fully charged 3S packet has 10.8V, only 1V difference.
    In "AA" there isn't much, in "18650" there is quite a selection.
    The maximum discharge current is much greater than for "AA" cells.
The discussion revolves around the maximum current draw from AA rechargeable batteries for a remote control car, with the original battery configuration being 9.6V from 8 AA cells. Users suggest that while AA batteries can theoretically handle various currents, they are not suitable for continuous high current draws, such as 8A, which could damage them. Alternatives like 18650 cells and LiPo batteries are proposed, but the original poster prefers AA or 18650 batteries for their versatility. Some specific high-rate discharge AA batteries, such as the GP270AAHC, are mentioned, which can handle up to 7.5A. The consensus is that standard AA batteries are not recommended for high current applications, and users should consider the discharge rates and voltage requirements carefully.
