AA Battery Life vs Current Draw: Is Power Output Lower at Higher Amperes for USB Chargers?
426 6
  • #1 21673031
    Bee-You T
  • NiMH charging requires proper algorithm control
    #2 21673032
    Richard Gabric
  • #3 21673033
    Bee-You T
  • #4 21673034
    Gary Cole
  • #5 21673035
    vikasbly44
  • Overcharging can overheat and damage batteries
    #6 21673036
    Frank Bushnell
  • #7 21673037
    Bee-You T
The discussion addresses whether higher current draw from AA NiMH batteries in USB chargers reduces total battery life and power output. It is confirmed that battery life decreases as current increases due to internal heating and potential damage, especially if charging current exceeds manufacturer recommendations. Proper charging requires controlled current and voltage with appropriate algorithms to avoid overheating and damage. Using a charger with a current rating significantly above the battery's specification can shorten battery lifespan or cause failure. Low self-discharge NiMH batteries were specifically referenced. Reliable charging involves integrated charging chips and adherence to recommended charging protocols. BatteryUniversity.com is recommended for detailed technical guidance on NiMH battery charging and management.
