Sound Blaster Live 5.1 SB0060: Connecting on Windows 7 64-bit, Driver Options & Setup Steps
loti990 6828 7
  • Need Windows 7 64-bit driver setup help
    #1 16522935
    loti990
    Hello, I have an old sound card, I used it on windows xp 32 bits before. I had problems with connecting there already, because it did not give sound at all, but I fired all the drivers, I connected a window with new equipment and it worked somehow. Now I have win7 64 bits and I can not connect it in any way, I have already checked a lot of drivers from the net but somehow it does not work. The card is 100% functional on the old wines, it picked up nicely much better than the integrated. Will you help make her pick up?
  • #2 16522973
    jmnlabs
    Level 19  
    Help: 40
    Rate: 50
    There was something about it here:
    Link
  • #3 16523055
    loti990
    Those drivers are up to 2gb ram and I have 8
  • #4 16523330
    iron64
    Help: 648
    Rate: 313
    Install KX drivers for 64-bit system.
  • #5 16524811
    RADU23
    Help: 2428
    Rate: 1732
    Enter hardware identifiers from device manager =>
    https://www.elektroda.pl/rtvforum/topic1228905.html
  • #6 16524900
    Dra98
    Help: 1321
    Rate: 1076
    Registry entry can be applied when hardware has 4-8 GB of RAM
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\ossrv]
    "HighestAcceptableAddress"=dword:e0000000
    "LowestAcceptableAddress"=dword:00000000
    From my observations, there was probably a problem with the microphone without this entry - old history.
    Or there is fun and searching, e.g.
    http://www.kxproject.com/down.php
    http://kxproject.com/faq.php?language=en#Q15
    https://www.elektroda.pl/rtvforum/topic2051653.html
  • #7 16526504
    loti990
    After installing the drivers, kx writes: No kX devices found. Reinstall the drivers. kX Error: kX device not found
    He sees the card normally in the component display program and here are the identifiers:
    PCI / VEN_1102 & DEV_7002 & SUBSYS_00201102 & REV_07
    PCI / VEN_1102 & DEV_7002 & CC_098000
  • #8 16528050
    loti990
    I fixed the guns, found some patched versions of these kx
    https://github.com/kxproject/kx-audio-driver/issues/10
    By the way, I have one more question. I bought a new Seagate Barracuda ST1000DM003 drive, but there is a strange noise from it, it is not regular. Have it replaced, do the hdd drives work like that? I recorded the link below with my phone, how can you hear it
    [movie: 765d34a637] https://filmy.elektroda.pl/40_1497416597.mp4 [/ movie: 765d34a637]
The discussion revolves around connecting the Sound Blaster Live 5.1 SB0060 sound card on a Windows 7 64-bit system after previous use on Windows XP 32-bit. The user reports issues with sound output and driver compatibility. Suggestions include installing KX drivers specifically for 64-bit systems, checking hardware identifiers from the device manager, and modifying registry entries to resolve microphone issues. The user encounters errors indicating that no KX devices are found after driver installation but later finds patched versions of the KX drivers that may resolve the issue. Additional concerns about a new Seagate Barracuda hard drive's noise are also mentioned.
