No DVB-T signal - No terrestrial TV signal. I am looking for a reason.
demienko 7764 5
  • #1 16477765
    demienko
    At my friend's, some fitter laid TV-SAT about 5 years ago. The SAT signal is there, and the terrestrial TV signal DVB-T disappeared simultaneously on 3 TV sets because they are connected to the same antenna. The first suspicion fell on the power supply which is connected to one of the plugs / TV sets.
    This is a ZZA-7 power supply with a crossover (described as a + 12V crossover), which is probably the original for the Telmor Antenna ... I don't know if the power supply diode was lit on the power supply before, but at the moment it is off ... so I took off the plug where the power supply is connected and the voltage is measured ... the meter shows 9V - is it the correct voltage? I know that antenna amplifiers are usually powered with a voltage in the range of 5-12V or maybe even 0-12V ... and I do not know how it is in this case, maybe this 12V is required? The plug also has such a spiral wire, on the plus wire, between the power supply and the cable wire ... I measured behind this spiral, maybe it causes a voltage drop and 9V is ok and should I look elsewhere for a problem? Only with this one receiver is the power supply, in the other two the cable is directly connected to the wall socket. I also found a box, something probably a multiswitch with the symbol AZR / 1-69 / 4 ... now after the symbol I read that it is an antenna splitter, powered by 12V ... so probably the wrong voltage is reaching this splitter? I mean the 9V from this ZZA-7 power supply ...
    Can any spec confirm my assumptions? Because I do not know whether to order a new power supply, or maybe this splitter, or climb specifically on the roof and measure the antenna directly? Thank you in advance for any hint ...
    goldi74
    Help: 1367
    Rate: 1538
    demienko wrote:
    I don't know if the power supply LED was lit on the power supply before, but it is not lit at the moment ...
    And it should shine.
    andpol 33
    Help: 513
    Rate: 1145
    The power supply is to be 12V and the end (if it is a 12V power supply, it is written on the housing). You have to start from this.
  • #4 16477795
    demienko
    Yes, the power supply is described as 12V. The power supply specification also says that it gives 12V / 100mA. So, I think the diagnosis was successful - the ZZA-7 power supply is kicked, which, above all, does not supply the AZR / 1-69 / 4 splitter which, according to specification needs a 12V power supply ... In that case I will replace the power supply and let me know what the effect is ;-) Unless someone else adds something :-) Thanks in advance for your suggestions ...
    Darek.S
    Help: 216
    Rate: 975
    demienko wrote:
    In that case, I will replace the power supply and let me know the effect ;-) Unless someone else adds something :-) Thanks in advance for your suggestions ...
    Well, the power supply is a few dozen zlotys and the cost of repair (part) is pennies.
    But with these amounts I recommend a new one :wink:
  • #6 16482542
    demienko
    I close the topic. After replacing the power supply, everything returned to normal, i.e. my analysis was correct.
    Thanks for confirming some information :-) I don't often deal with such topics, so I prefer to be sure.
    greetings :-)
