Samsung Galaxy S4 i9505: No SIM Card Detection, SIM Card Reader Replacement, and Motherboard Issues
kookoo1991 4968 9
How can I fix a Samsung Galaxy S4 i9505 that intermittently loses SIM detection, reads the SIM only when the reader is pressed, and still shows no SIM after a motherboard swap?
Replace the SIM/SD card reader first, and one user reports the repair also required recalculating the PM system [#16482027] If the phone reads the SIM only while you press the reader, the problem is not the SIM card itself but a bad contact or connection on the board/modem path [#16486978][#16488750] Another suggestion was to reflow the NFC section; if that does not help, the fault may be broken modem connections [#16482037] A damaged reader or a defective replacement board was also mentioned as a possible cause [#16479580]
  • #1 16479427
    kookoo1991
    Hello everyone,
    I know this is a topic on many forums, but I have not found a solution to the problem. Initially, the phone began displaying from time to time the message SIM card was removed, with time it happened more often, until he read it only once in a while. Despite this, I used it to use wifi or listen to music. In the meantime I bought a used card reader, but nothing helped. Later I bought a second new original, but after a few days the problem returned and the phone could not read the sim. He often had one that he saw alternately once a memory card and once a sim, both rarely at once. It recently turned off and refused to turn on anymore, nothing helped, it was impossible even to enter recovery mode. So it was decided to buy the motherboard. Today came, the translation went smoothly, but she cannot see the SIM card. He reads the memory card, I don't know what to do next. I tested both today and in the past on the plus card and two virgine mobile, which work fine on other phones. Tomorrow I will buy a starter from play or orange, but I doubt that he would suddenly start reading it.
    Thank you in advance for any tips.
    nutergsm
    Help: 1034
    Rate: 1665
    Either you have a damaged disc or a reader in this "new" disc.
  • #3 16479607
    kookoo1991
    The reader is almost new, so rather efficient, while the disc comes from disassembly and in theory everything should be functional. But it varies with it. In another topic, it was suggested that it was the NFC chip, and therefore part of the motherboard.
  • #4 16479614
    nutergsm
    Help: 1034
    Rate: 1665
    If you have the chance to return this CD, please return it.
  • #5 16481977
    Spartan33
    Help: 41
    Rate: 97
    On my S4 i9505 stock 4.4.2 yesterday when writing a post in the net appeared information as in the subject, no sim card, and that you need to restart the device, after restart, no sim card, I took out the sim card and inserted it again, it works. This is the first time I have such a message.
  • #6 16482027
    xbox-serwis.eu
    Help: 52
    Rate: 210
    Hello, replace the SIM and SD card reader with a new one, walkthrough below. I was helped by the recalculating PM system ...
    Regards
    XBOX-SERWIS.EU
    Karmelicka 15, Kraków, 31-131 | Company Website: http://www.xbox-serwis.eu
  • #7 16482037
    misiekelk
    Help: 47
    Rate: 121
    A typical fault with these discs. NFC reflow if it doesn't work then you have broken modem connections. Once I got mad and fixed myself. I unsoldered the modem with new balls and it sped but a lot of work with glue.
  • #8 16486978
    kookoo1991
    The motherboard is functional, because when I plug in the SIM reader and hold it with my finger, the sim reads, unfortunately after taking my finger the message "SIM card removed". I have 4 readers and 2 of them work, but they are without this adhesive film, is it possible to buy and stick it? Yesterday I received another ordered reader, but I wanted to save and ordered one of the cheapest and the card does not snap in it, which is a slight movement also causes a message to appear.
  • #9 16488750
    misiekelk
    Help: 47
    Rate: 121
    Just this pressing helps for a moment it does not connect you modem.
  • #10 16491496
    kookoo1991
    So the motherboard?
    ps. Is it the motherboard's fault because I don't know whether to send it back in such a case?
The discussion revolves around issues with the Samsung Galaxy S4 i9505, specifically related to SIM card detection failures. The user initially experienced intermittent messages indicating that the SIM card was removed, which worsened over time. Despite replacing the SIM card reader multiple times, including a new original part, the problem persisted. The user then replaced the motherboard, but the device still failed to recognize the SIM card, although it could read the memory card. Various responses suggested potential causes, including a faulty SIM card reader, issues with the NFC chip, and modem connection problems. Some users recommended pressing the SIM reader to establish a temporary connection, while others discussed the possibility of needing to replace the motherboard again. The conversation highlights the complexity of diagnosing and resolving hardware issues in mobile devices.
