Xperia Z3 SIM Card Detection Issue: Possible Damaged Slot or Connection - Restart Required
epicktroll 4905 5
  • #1 16343309
    epicktroll
    Hello, I have such a problem with xperia z3 does not see the sim card even though it is inserted but when I start the phone again suddenly the sim card is found and after some time not specified because it works 2 days and once after an hour you need to reset the phone.
    Could this be a damaged SIM card slot?
  • #2 16343324
    KamGr
    Help: 77
    Rate: 203
    Have you checked how the phone behaves after inserting other cards?
  • #3 16346200
    epicktroll
    That's what I did at the very beginning, before I started the topic, it reacts the same to every card :(
    kamil2114
    Rate: 12
    Has a software update been made?
    luk90
    Help: 8
    Rate: 24
    Check the correctness of the imei number * # 06 #
    If you crash null it hurts your hardware.
    A professional hand will heal.
  • Downgrading firmware restored SIM card detection
    #6 16438276
    epicktroll
    That's how the update was done - and that's why he can't see this card.
    I downloaded the flashtool and firmware before the upgrade, I downloaded and it works :D
    I accidentally made sure that this update was guilty because after the first installation of this old firmware I accidentally allowed it to update and the problem reappeared.
    I have installed the old firmware again and it works and now I will not allow any system updates.
    In case anyone has questions, I don't close the topic :D
    Thank you for answering my question and for your help :D
