Samsung Galaxy S5 Shuts Off & Resets on Start Screen Only When Disconnected from Charger
yoshimura99 5478 2
  • #1 16479968
    yoshimura99
    I don't know if I chose the topic correctly if I am sorry.
    I have had a Samsung galaxy s5 for 1.5 years, so far it has worked very well, however, for several days a problem has arisen, namely when the phone is disconnected from charging turns off and resets on the start screen I will add that when it is connected to charging the network is everything works perfectly fine. What could be the reason for this problem? Could it be caused by a broken battery? , Greetings
  • #2 16479986
    sosarek
    Help: 9320
    Rate: 15532
    Yes, you should connect another one to check.
    Z
    Pka, Poznań, 60-850
  • #3 16479997
    nutergsm
    Help: 1034
    Rate: 1665
    It looks like a damaged battery. To be 100% sure you must substitute another.
