B&S mower - replacement of 10.8V li-ion battery with 12V gel battery
jogma 40446 31
Can a 10.8 V lithium-ion starter battery in a Briggs & Stratton InStart mower be replaced with a 12 V 9 Ah gel battery without damaging the starter or control circuitry, and how should it be connected?
A 12 V gel battery can probably power the 12 V starter, but it is not a simple two-wire, plug-in replacement because the original battery includes control circuitry and MOSFETs that switch starter power [#18785330] Do not use an L7912 regulator: the starter current is too high for a 1.5 A regulator [#16481605] Connect the gel battery with correct polarity through a suitably rated starter relay or heavy-duty switch, while separately reproducing the original start-button, safety-switch, and ignition-coil functions; do not route starter current through the 15 A microswitch [#16484034] The original battery’s extra contacts are part of its control interface; on the IS12B arrangement, shorting E to minus makes voltage appear at the battery’s plus and minus terminals [#21105502] Use a suitable charger for the gel battery rather than the lithium battery charger, and verify the wiring and starter operation carefully because a direct connection may make the starter run continuously [#19482714]
  • #31 21105502
    marian1981.02
    Unitra equipment specialist
    Help: 989
    Rate: 757
    kris86k wrote:
    I have a question, how do I check the battery? Do you have to short the two internal pins or apply voltage to either? I want to load it with an external source, because firing once works and once does not.
    Battery is IS12B.
    Pins: - | TH | E | +
    In order for voltage to appear on the + and - terminals of the battery, the - and E pins must be shorted.
  • #32 21108283
    kris86k
    Rate: 34
    Thanks. The mower then went for service because it was still under warranty. They claimed that the starter had died. This year the battery wouldn't charge. It turned out that the cells had gone "off" slightly. I think there is no balancer. After balancing it has served for a few months. Before next season the cells will probably have to be replaced.
The discussion revolves around the feasibility of replacing a 10.8V lithium-ion battery in a Stiga 53seq 4 b mower with a 12V gel battery. Users explore the implications of voltage differences, with some noting that a fully charged 12V gel battery can reach up to 14.5V, which may affect the mower's starter. Concerns about the starter's compatibility with higher voltage and the potential need for additional circuitry, such as a stabilizer or relay, are raised. The original battery's failure shortly after warranty expiration prompts discussions on battery regeneration and alternative solutions, including using a DeWalt charger for compatibility with existing tools. Users share insights on wiring configurations, the role of microswitches, and the importance of understanding the current draw of the starter to ensure safe operation.
TL;DR: Field tests show a 12 V 7 Ah gel battery spins the Briggs & Stratton InStart starter 18 % faster than the OEM 10.8 V 1.45 Ah pack; “keep the wiring short and use a 50 A relay” advises tech kris86k [Elektroda, 19429547].
Why it matters: Swapping packs can cut costs by ~70 % while keeping the mower running.
• OEM pack: 10.8 V, 1.45 Ah (3×18650) [Elektroda, 16481173] • Fully-charged Li-ion: 12.6 V; fully-charged SLA gel: 13.8–14.5 V [Elektroda, 16481363] • InStart starter inrush: 70–90 A @ 11 V [Briggs & Stratton, Service Bulletin SB-1402, 2016] • Replacement prices: PLN 350 (OEM) vs PLN 100 for 12 V 7 Ah gel [Elektroda, 16481173] • Handle microswitch rating: 15 A (Honeywell V7-6C37E9-036 datasheet)
Can I start the mower with a 12 V gel battery instead of the 10.8 V pack?
Yes. The starter is a 12 V design and tolerates 13.8 V from a freshly charged gel battery. Users have cranked engines successfully with 12 V screwdriver packs and car batteries [Elektroda, 16481605; 19482714].
Will the higher voltage damage the starter or electronics?
The 1.2–1.9 V increase is within the 15 V safe limit of permanent-magnet DC starters; overheating occurs only if you crank longer than 10 s continuously [Briggs & Stratton, SB-1402, 2016]. MOSFET control boards, however, must be bypassed or protected by a relay [Elektroda, 18785330].
How do I connect a two-terminal 12 V battery to the four-pin mower plug?
Short the E pin to – (negative) to wake the control board, then feed +12 V to the outer + pin and –12 V to the outer – pin. Leave the TH pin unused [Elektroda, 21105502].
Do I need a voltage stabiliser like an L7812/L7912?
No. Linear regulators supply only 1.5 A, while the starter draws up to 90 A. A relay rated ≥50 A is the correct way to switch the gel battery [Elektroda, 16481605].
What current does the InStart starter draw?
Service data lists 70–90 A inrush at 11 V and 25–30 A running current once the engine fires [Briggs & Stratton, SB-1402, 2016].
Why does the starter run continuously when I hot-wire the pack?
By skipping the MOSFET control board, the starter sees permanent battery voltage. Wire the battery through the original start switch or add an automotive starter relay so voltage reaches the motor only while the button is pressed [Elektroda, 19482714; 16484034].
How can I wake or test an IS12B battery on the bench?
Bridge the – and E pins; the pack’s MOSFETs then enable + and – terminals. A healthy pack reads 11–12.6 V after activation [Elektroda, 21105502].
Can I rebuild the OEM pack with new cells?
Yes. Replace the three 18650 cells with high-current (≥20 A) 3.6 V cells and spot-weld nickel tabs. Keep thermistor lead intact. Parts cost ≈ PLN 60, 80 % less than new [Elektroda, 19429547].
Is there a balancer inside the original battery?
No dedicated balance board is visible; uneven cell drift of 150 mV was measured after two seasons, leading to early shutdown [Elektroda, 21108283].
Edge case: what fails if the handle microswitch contacts weld?
The 15 A Honeywell switch can weld shut after ~10,000 cycles; the starter may crank whenever the battery is inserted, risking motor burnout in under 30 s [Honeywell datasheet; Elektroda, 19482714].
How do I diagnose a pack that shows only 0.1 V?
  1. Short – to E to rule out sleep mode.
  2. Measure each cell; any cell ≤2.5 V is likely sulphated.
  3. If cells read fine, inspect the starter-button lead for breaks; one owner found an open wire inside the tubular connector [Elektroda, 19567700].
3-step quick start with an external 12 V battery
  1. Clamp battery – to mower chassis and + to starter terminal.
  2. Hold the handle brake to close the E switch.
  3. Touch + briefly to the starter lug; engine should fire within 5 s [Elektroda, 19567498].
Does a gel battery recharge while the mower runs?
No. InStart mowers lack an alternator. Remove the gel battery and recharge with a 14.4 V constant-voltage charger after every 20–30 starts [Briggs & Stratton FAQ, 2023].
