Briggs & Stratton 12HP Engine: Yard Man Ride-on Mower, Ignition Switch & Charging Coil Issues
Martin 007 10080 9
Why does my Yard Man ride-on mower only crank when I disconnect the charging-coil wires, and which safety-switch or relay wiring should I check?
The starter is most likely being blocked by the mower’s safety-interlock/relay circuit or a wiring mismatch, so check that system before blaming the solenoid or charging coil [#16578805][#16578864] Inspect the under-seat protection, the relay it feeds, the PTO switch, and other safety switches such as the basket switch, because those are the components most often mentioned as stopping the starter circuit [#16578805][#16578864][#16579004] The delayed beep you hear under the seat points to the safety circuit switching in after a delay, which fits an interlock/relay problem [#16578856][#16579004] Also verify the wiring against a diagram: the charging-coil leads in the loom are red and yellow, and the yellow wire from the ignition switch is not connected anywhere in your harness, which suggests the current wiring may not match the correct schematic [#16579316][#16678424]
  • #1 16578773
    Martin 007
    Hello to all forum members!
    At the beginning of my post I will try to accurately describe the situation and the problem that has been bothering me for a long time. Some time ago I bought a Yard Man ride-on mower with a damaged engine (broken connecting rod). I was able to buy an efficient engine of the same power and install it in the machine. However, there was a problem with starting the engine. Turning the key in the ignition switch, the starter does not react at all. However, when I disconnect the cables from the charging coil, everything is fine. The engine starts with the arrow. Charging on a running engine is about 14V. Even after connecting the cables going to the charging coil, the engine does not go out. After turning off, again zero reaction to the key. The solenoid is operational. I took a photo of the ignition switch and the cube connecting the wires of the charging coil. I am asking for suggestions on what to do here.
    Briggs & Stratton 12HP Engine: Yard Man Ride-on Mower, Ignition Switch & Charging Coil Issues Briggs & Stratton 12HP Engine: Yard Man Ride-on Mower, Ignition Switch & Charging Coil Issues Briggs & Stratton 12HP Engine: Yard Man Ride-on Mower, Ignition Switch & Charging Coil Issues
  • #2 16578805
    DriverMSG
    Help: 3984
    Rate: 4891
    Check the electrical installation carefully and check the "path" that the current flows from the ignition switch to the starter.
    The most common is the protection under the seat (the starter only turns when you are sitting) and it can be led through a relay. Unfortunately, I do not have a diagram to give a more precise hint.
  • #3 16578826
    carrot
    Moderator of Cars
    Help: 1317
    Rate: 3607
    This engine does not sometimes have an oil level sensor that prevents too little start?
  • Intermittent seat-area beep restores ignition power
    #4 16578856
    Martin 007
    There is no sensor under the seat. When I sit on the chair it is the same, it does not give electricity to the ignition at all. I have recently noticed that after 2-3 min. there is a beep somewhere under the seat, under the body and for a few seconds electricity goes to the ignition and I can start the engine. After turning off it is the same, after turning the key, zero reaction until it beeps under the seat ... and so on; /
  • #6 16579004
  • #7 16579094
    kortyleski
    Help: 957
    Rate: 3860
    Rycho T wrote:
    Disconnect the cable going to the ignition coil (the thin one), as then it will light up as I wrote above.
    How could that make any sense?
  • #8 16579107
  • #9 16579316
    Martin 007
    I will add that the cables (see the first photo) that go in the conduit run from the charging coil to the ignition switch (red and yellow). Then the yellow wire in the ankle from the ignition switch separates, but is not connected anywhere.
  • #10 16678424
    jandeka
    Hello. Here is a diagram, maybe something will help.
The discussion revolves around issues with a Yard Man ride-on mower equipped with a Briggs & Stratton 12HP engine. The user reports that the engine fails to start when the ignition switch is engaged, although it starts successfully when the charging coil cables are disconnected. The charging voltage is approximately 14V when the engine is running. Forum members suggest checking the electrical installation, including the ignition switch, safety circuits, and potential relays. The user notes intermittent electrical connectivity, indicated by a beep from under the seat, which allows the engine to start temporarily. Additional insights include the possibility of an oil level sensor and the importance of checking the PTO switch and safety switches.
