How to Disable a Faulty Proximity Sensor in LG Phone After Screen Breakage?
Charleselektro 5154 4
  • #1 16482230
    Charleselektro
    Hi. How to disable the proximity sensor in LG? There is something wrong with it hardware because today the screen broke and the crack is passing through where it is (although the person who uses it previously complained that something is not working properly). I tried to calibrate the application from google play to nothing. Is the warranty still available when the glass is broken? I want to turn off this sensor because the screen goes blank during the conversation and it cannot be turned on again (you have to remove the battery). If I disassemble the phone, I will lose the warranty? Best regards and I hope for help as soon as possible!
  • #2 16482294
    sosarek
    Help: 9320
    Rate: 15541
    Is it hard to read the warranty terms and provide the phone model?
    Z
    Pka, Poznań, 60-850
  • #3 16482327
    Charleselektro
    LG great H500f
  • #4 16482459
    mobista
    Help: 257
    Rate: 365
    If you unskillfully open the device, you will lose the warranty. If your glass has broken in the place where the proximity sensor is located, the break will most likely cause the sensor light to be reflected. You can turn on ending a call with the "power" button in the phone options.
  • #5 16483495
    winmap
    Help: 361
    Rate: 754
    There is no guarantee that every service that sees a broken glass and so called wine on you, no matter what would break, unless you have additional insurance on the phone which almost no one buys anyway.
    As far as I remember, it is possible to turn off the accelerometer in the software somewhere, but unfortunately I do not remember what and how, so ask, keep looking. :)
