Msonic MC7468NK - The Bluetooth adapter does not install drivers for other devic
omen08 3219 1
  • #1 16484068
    omen08
    Rate: 10
    Hello, I have a problem, as in the topic I bought the Msonic MC7468NK Bluetooth adapter and after connecting it installed nicely, etc. and normally detects devices, but when I want to connect, I install the software / drivers and in each device it comes out the same:
    External bluetooth device - driver not found
    Standard serial port via bluetooth (COM3) ready to use
    Standard serial port via bluetooth (COM4) ready to use
    And I don't know if I'm doing something wrong or something is wrong. I tried to connect the phone, entered the pin and the same, I tried to connect the Manta wireless speaker the same and the Samsung HW-J355 Soundbar the same. Help
  • #2 16485532
    omen08
    Rate: 10
    I bought a new Asus adapter for PLN 60 which had drivers on the board and it works. As you can see, Msonic did not have them memorized and therefore does not work.
