[Solved] JBL GO bluetooth speaker - connecting to a computer with Windows 7 64 bit
human54675 47565 10
How can I connect a JBL GO Bluetooth speaker to a Windows 7 64-bit desktop computer?
The problem was not a separate JBL GO driver; it was the Bluetooth adapter and its Windows 7 driver compatibility. A paid BlueSoleil stack could connect the speaker, but only temporarily and with poor audio quality [#17817439] The thread’s final solution was to replace the cheap Esperanza Bluetooth 2.0 dongle with a Logilink BT0015 adapter whose Windows 7 drivers worked correctly, after which the speaker connected normally [#17830351][#17919625]
  • JBL GO needs Bluetooth audio support, not drivers
    #1 17782060
    human54675
    Rate: 8
    Good day.
    I have a JBL GO speaker:
    I want to connect it to a desktop computer. I just don't know how to do it.
    I bought this Bluetooth adapter Esperanza Bluetooth 2.0 USB:
    I connected and successfully installed the Bluetooth adapter.
    Now I'm trying to add a new bluetooth device, i.e. my JBL GO speaker to my computer:
    After which I am told that the device has not been successfully installed and I do not know what's going on?
    JBL GO bluetooth speaker - connecting to a computer with Windows 7 64 bit JBL GO bluetooth speaker - connecting to a computer with Windows 7 64 bit JBL GO bluetooth speaker - connecting to a computer with Windows 7 64 bit JBL GO bluetooth speaker - connecting to a computer with Windows 7 64 bit
    Does this speaker have any drivers for Windows 7 64 bit ?? I got it as a gift and I don't remember if he had any driver board.
  • Bluetooth driver installed but speaker still won't connect
    #3 17782298
    human54675
    Rate: 8
    I tried to upload Intel(R) Wireless Bluetooth(R) drivers for Windows 7 *
    https://downloadcenter.intel.com/download/28510/Intel-Wireless-Bluetooth-for-Windows-7-
    JBL was supposedly successfully installed, without any exclamation marks.
    The further problem is that now I go into the sound / playback and select one of the bluetooth devices on the device and do not want to connect, I tried to turn off / on the device several times, something is wrong. :P
    I don't respond at all to clicking connect.
  • #4 17782307
    Pedros050
    Help: 2471
    Rate: 3926
    Will not connect you after it is unplugged, unplug the speakers from the green socket.
  • #5 17782660
    human54675
    Rate: 8
    It doesn't help, I tried different ways, it seems to me that this speaker does not work just under Windows 7 or the Bluetooth 2.0 adapter is not compatible with a speaker that has bluetooth 4.1.
  • #6 17782823
    Pedros050
    Help: 2471
    Rate: 3926
    I am of the same opinion.
  • #7 17810551
    human54675
    Rate: 8
    Is there any other solution? Is there any bluetooth transmitter that can connect a pc - JBL GO speaker?
  • #8 17817439
    human54675
    Rate: 8
    I was able to connect this speaker through the bluesoleil program. Unfortunately, this paid program works only 30 days and the quality of the transmitted audio is very poor.
    I am looking for some alternatives, maybe there are some bluetooth adapters that have their own software, because these standard drivers don't work to connect this speaker.
  • #9 17830351
    human54675
    Rate: 8
    I solved the problem I bought a more expensive BT adapter instead of this Esperanza shit, which does not work at all under Windows 7 I bought the more expensive logilink BT0015 model again and it works elegantly, but the 100m range is a bit fake, at home I just need to go a few rooms and the sound stops.
  • #10 17891551
    Pedros050
    Help: 2471
    Rate: 3926
    100M is in the open space and not in the apartment walls suppress BT signal.
  • #11 17919625
    human54675
    Rate: 8
    I solved my problem myself. I was simply changing the adapter to a different one that had drivers working under windows 7.
    Subject to close.
The discussion revolves around connecting a JBL GO Bluetooth speaker to a desktop computer running Windows 7 64-bit using an Esperanza Bluetooth 2.0 USB adapter. The user successfully installed the Bluetooth adapter but faced issues when trying to add the JBL GO speaker, receiving an installation error. Subsequent attempts to connect the speaker were unsuccessful, leading to speculation that the Bluetooth adapter may not be compatible with the speaker's Bluetooth 4.1 technology. Suggestions included using alternative Bluetooth transmitters or software like Bluesoleil, which, while functional, had limitations in audio quality. Ultimately, the user resolved the issue by purchasing a more compatible Bluetooth adapter, the Logilink BT0015, which worked effectively despite some range limitations.
