Dasan h640gw Router: Root Login Issue with Unchanged, Correct Password
Khalif1997 10053 10
Why can’t I log in as root to my Dasan H640GW router anymore even though I’m using the same password that used to work?
Your ISP or supplier likely changed the router’s configuration or access credentials remotely, even if the firmware version did not change, because this is operator-owned equipment and it can be reprogrammed from their server [#16484831] [#16485005] [#16485841] On this model, the web interface normally uses admin/user, while telnet uses root/admin, so if root access still fails you should ask the supplier to restore access or use your own router [#16485457] [#16485005]
  • #1 16484233
    Khalif1997
    I have a Dasan h640gw router, which I got from a company that has a fiber optic network. The problem is that I can't log in as root for a long time. I used to do it once, and now I keep showing the message that the password is incorrect, even though I haven't changed it, and I type the same one that I used to log in.
  • #2 16484468
    jimasek
    Help: 3783
    Rate: 2681
    How do you know that the company has not changed the router configuration.
  • #3 16484552
    Khalif1997
    Because I have the same router all the time and I was able to enter with the same login and password.
  • #4 16484831
    jimasek
    Help: 3783
    Rate: 2681
    Configuration change / update may have been done remotely. Ask the supplier.
  • #5 16484910
    Khalif1997
    The problem is that there was no update, it's the same version all the time.
  • #6 16485005
    KOCUREK1970
    Help: 3862
    Rate: 5490
    But it is still the operator's equipment - it changed access data remotely.
    Maybe precisely because you logged in to it as root - on the operator's servers there are logs of the work of this equipment, it checked and closed your access completely.
    Connect your own router and tinker there.
  • #7 16485152
    jimasek
    Help: 3783
    Rate: 2681
    Just like a colleague writes @ KOCUREK1970 he could change the configuration remotely regardless of the update.
  • #8 16485409
    Heinzek
    Help: 554
    Rate: 494
    User account working? user / user
    ps. This router, by default, has no root account, only admin and user
  • #9 16485448
    Khalif1997
    As there is no default root account as is. The user account works without any problem.
  • #10 16485457
    Heinzek
    Help: 554
    Rate: 494
    via www is admin and user
    via telnet is root and admin
  • #11 16485841
    yogi009
    Help: 848
    Rate: 2655
    We don't know what the supplier is. In Vectra it is so that you can reset their modem to factory settings, and when logging into their server it will be reprogrammed to the state planned by the provider.
The discussion revolves around a user experiencing login issues with a Dasan h640gw router, specifically being unable to access the root account despite using the same password that previously worked. Responses suggest that the router's configuration may have been altered remotely by the service provider, which could explain the login failure. It is noted that the Dasan h640gw router does not have a default root account, and users typically access it via admin or user accounts. Suggestions include checking with the supplier for any changes and considering the use of a personal router for further configuration.
