[Solved] Which Mower Drive to Choose: Rear vs Front for 20 Ares, Uneven Terrain, 6-7 HP, Grass Basket
Emi53 8913 8
  • #1 16484346
    Emi53
    Rate: 27
    I have 20 ares to mow on uneven terrain and I do not know what drive will be better rear or front, the grass will be caught in the basket. Power is 6-7 HP.
  • #2 16484751
    marek49ae
    Help: 57
    Rate: 254
    I would choose the back. When filling the basket, the pressure on the drive axle increases. I also have uneven terrain and sometimes with a full basket the front wheels go up.
  • #3 16486996
    Emi53
    Rate: 27
    Rear - I thought so too, but there are also 3 wheels in front, one wheel is probably better for uneven terrain. What do you say....
  • #4 16487775
    marek49ae
    Help: 57
    Rate: 254
    I have not dealt with three-wheeled mowers. When I was buying the current one, I chose the one with large wheels.
  • Rear drive slips less with a full basket
    #5 16488195
    jarekstryszawa
    Help: 49
    Rate: 482
    I have both types of drive, i.e. 4 wheel drive and rear and front drive. In fact, the rear drive has less slip, especially when the basket is loaded, compared to the front drive. However, for me, mowing a plot of irregular shape is more convenient with a mower with front drive because with obstacles and tight turns, I do not have to turn the drive on and off, I just gently lift the wheels and then lower it further driving.
    This is just a great thing for me, of course if someone has a large plot of regular shape, it does not matter that much.
  • #6 16725572
    Emi53
    Rate: 27
    I didn't solve the topic.
  • #7 16725583
    tadkli9743
    Help: 70
    Rate: 280
    Welcome.
    I had a similar dilemma and I solved it by investing in the MTD tractor and now I have mowing comfort.
    best regards Which Mower Drive to Choose: Rear vs Front for 20 Ares, Uneven Terrain, 6-7 HP, Grass Basket
  • #8 16727081
    Staszek49
    Help: 228
    Rate: 1140
    Gardeners say that a tractor should be bought when you have more than 6-7 ares to mow, and you have 20.
  • #9 17596000
    Emi53
    Rate: 27
    I bought a rear wheel drive mower with large wheels.
The discussion revolves around choosing between rear and front drive mowers for mowing 20 ares of uneven terrain with a power requirement of 6-7 HP. Participants suggest that rear drive mowers are preferable due to reduced slip when the grass basket is full, while front drive mowers offer better maneuverability around obstacles. One user mentions their experience with both types, highlighting the convenience of front drive for irregularly shaped plots. Additionally, a recommendation is made for investing in an MTD tractor for enhanced mowing comfort, especially for larger areas. The consensus leans towards rear drive for stability, but front drive is noted for its agility in tight spaces.
