[Solved] G-Force XSZ51A Mower: Is it Worth Buying? Pros & Cons, Loncin LC1P75 Engine, 4 Mowing Methods
wojtek1234321 15114 9
Is the G-Force XSZ51A mower worth buying for a roughly 2000 m² uneven orchard/yard, and how reliable is its Loncin LC1P75 engine and chassis?
It may be worth buying if your priority is strong cutting power for a low price, but the thread raises doubts about the long-term durability of the deck and other non-engine parts [#17197152][#17181436] One owner says that after a year and about 3200 m² of mowing, it was one of the best purchases they made and they would definitely recommend it [#17182545] Another reply says the mower has a powerful engine but a weaker housing, and suggests choosing a sturdier model like the World GRL530S for this kind of area [#17181436] A different commenter says one season is not enough to judge a mower meant to last many years, and that if you want something durable for years, you should buy a Honda mower instead [#17196528] Overall, the best-supported advice is that the G-Force looks attractive on paper and may work well, but its value depends on whether you accept possible tradeoffs in build quality and longevity [#17197152][#17181436]
  • #1 17145202
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    Only one short question: Is it worth buying this mower?
    https://kosiarka.pl/pl/300-kosiarka-g-force-xsz51a.html
    Description
    The main advantages of the G-Force XSZ51A mower:
    Enormous cutting performance and a large power reserve are ensured by the most powerful Loncin LC1P75 upper-gasoline engine with 224cm? capacity and 14Nm torque. The cast iron cylinder liner and crankshaft on steel ball bearings guarantee high engine life and increased resistance to shaft bending due to accidental impact on hard objects (root, stone, steel rod, etc.). The engine will cope with both dry and wet grass;
    Effortless driving of the G-Force XSZ51A mower is provided by rear-wheel drive with a transmission made by the French pioneer of drive systems for garden machines - the company General Transmissions;
    With the XSZ51A mower, we mow the grass in 4 ways - we can choose between collecting into the bin, side and rear discharge, and ecological grinding / mulching. All the elements needed to convert the mower in 4 modes (grinding plug, side discharge deflector) are standard equipment;
    Working in tall grass or on wet and muddy terrain is no problem for the G-Force mower thanks to the use of massive, wheeled wheels with aggressive, non-slip treads with a large diameter (20cm for front wheels and 30cm for rear wheels);
    The durability and life of the chassis is due to the cutting unit made of 2mm thick sheet with a thick layer of powder enamel;
    A quick change of cutting height in the range of 28 - 75mm for all wheels simultaneously is provided by one solid central lever;
    The capacious 60-liter collecting bin with a comfortable handle and filling indicator ensures a long working time without frequent emptying;
    Technical parameters:
    Engine make: Loncin
    Engine model: 1P75F
    Engine type: four-stroke combustion engine
    Engine capacity (cm? ;) : 224
    Oil tank capacity (L): 0.5
    Fuel tank capacity (L): 1.4
    Starting: manual
    Working width (cm): 51
    Cutting height min - max (cm): 2.8, 7.5
    Cutting height adjustment: central - all wheels together
    Drive: yes - rear wheels
    Drive speed control: no - constant speed
    Mowing functions: collecting to the basket, side discharge, grinding, rear discharge
    Body: steel
    Basket capacity [L]: 60
    Wheel bearings: ball bearings
    Wheel size front / rear (cm): 20, 30
    Weight (kg): 33.5
    The mowing area is around 2000 meters, a piece of orchard and yard. The mowing area is not a typical lawn, similar to what this movie, but it is fairly even and cleaned. Until now she has worked (since 2002 and for now she will work) Husqvarna jet 55S, unless I buy something. The current one is almost ending. Maybe not so much the engine, but the whole deck, drive, i.e. drive wheels and the whole wheel and drive bearings, transmission is still good, only the entire drive and cable activation lever has come out. The prices of these parts are quite high and I don't know if it is still worth starting. The price of this mower would suit me and judging from the description the engine power and other parameters also if you can trust this data. I am asking for an opinion and some hints.
    Best regards.
    https://www.youtube.com/embed/XuphQluXlFI
    G-Force XSZ51A Mower: Is it Worth Buying? Pros & Cons, Loncin LC1P75 Engine, 4 Mowing Methods G-Force XSZ51A Mower: Is it Worth Buying? Pros & Cons, Loncin LC1P75 Engine, 4 Mowing Methods
  • #2 17181436
    zagorski-tomasz
    Help: 8
    Rate: 141
    Mower with a powerful engine but the rest so-so, they made a compromise with a stronger engine and a weaker housing, as we know the engine itself is part of the success and this one is strong and heavy, I do not know if it is too heavy for this housing and to avoid unevenness after a few years he broke up, personally, if I chose World GRL530S, the engine is a bit weaker, but the housing is much stronger and more durable, for a given area you are calm enough.
  • #3 17182545
    crooveck
    I have this mower for a year, I have a lawn of about 3200m2 and this is one of the best purchases I've made recently. I would definitely recommend.
  • #4 17182617
    płetwa
    Help: 165
    Rate: 551
    We'll talk in 5 years.
  • #5 17196235
    sabor
    @FIN can you expand your statement? or pretend that it's been 5 years and talk now?
    I set myself up to buy this mower and would love to hear the expert's opinion ...
    and in what area do you mow? I have about 1200m, and this is not a golf course. lots of bumps, mostly wet grass, sticks, pebbles, molehills, some hardcore :D
  • #6 17196424
    płetwa
    Help: 165
    Rate: 551
    sabor wrote:
    @ fin and can you expand your statement? or pretend that it's been 5 years and talk now?
    Dude, don't look for the bottom in my speech, I just know that one season of operation is definitely not enough to fall in love with the purchase. we buy the mower for about 10 years. From the photo it looks quite decent.
    But I agree 100% with this statement:
    zagorski-tomasz wrote:
    Mower with a powerful engine but the rest so-so, they made a compromise with a stronger engine and weaker housing, as we know the engine itself is part of the success and this one is strong and heavy, I don't know if it's too heavy for this housing
    . You see, it's so common that we buy with our eyes, and what really matters is what you can't see at first glance. Sheet thickness, paint quality, cable quality, gears, shifters, or wheel bearings are normal rolling or some shoddy wreaths. The things I mentioned fly most often.
    And I don't know why the hell such a powerful engine. I have two mowers at home, both have less than 140cm3, smoke as much as nothing and I have not seen that one would moan when mowing.
    First: https://www.google.com/search?q=solo+primo+54...DkP7g2uLaAhVCJ5oKHXZ8BmoQ_AUICygC&giw=t280Rbi
    Second: http://archiwumalle.pl/kosiarka_z_nap%C4%99dem_nac_b_s_5_km_grudzi%C4%85dz-1_2004471786.html
    The first is about 20-22 years old and here I can say that it is a very good purchase, they are produced to this day, but not on indestructible HONDA gxv 140 engines, only on bikes. The second is Italian SANDRI GARDEN only on the CLASIC engine, from them NAC started importing. He is now 12-14 years old, but the tow truck replaced for the second year ago.
    And by the way there are two species of mowers, HONDA and all the rest. If you want a good mower for years, just buy a HONDA mower.
  • #7 17196484
    sabor
    @FIN first of all, don't get angry. Secondly, it's great that you have 12-22 years old mowers. but notice what your colleague asks:
    For me and probably a colleague, it probably depends on the comfort and functions of the mower (grinding, side discharge, adjusting the wheels with one move, easy firing, drive, etc.). It's like comparing cars from 20 years ago to today's ...
    I also have a 12-year-old mower and she traveled in such areas that it is a pity to talk and gave advice. So if you have experience with the G-Force XSZ51A mower, or with these engines or with drive, I would love to listen. So far it appeals to me:
    but that still doesn't eliminate her from the purchase. I invite you to a constructive discussion.
  • #8 17196528
    płetwa
    Help: 165
    Rate: 551
    I am not irritated at all. And I also answered a friend's question
    To sum up, I wouldn't buy that mower.
  • #9 17197152
    zagorski-tomasz
    Help: 8
    Rate: 141
    And what is Honda, you can see that the inscription is doing its job but with such quality as it used to be a long time ago, it was old times and the inscription now in most companies means only "high price, expensive parts and service" in this Gforce mower attracts engine power and a relatively low price, nothing more
  • #10 17571190
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    It's time to close the topic.
    Finally, a mower was purchased in June OLEO MAC GV53 TK ALLROAD 4 .
    Engine make / model: Emak K 800 OHV
    Engine capacity: 196 cm?
    Works perfectly.
    I close the topic.
The G-Force XSZ51A mower, equipped with a powerful Loncin LC1P75 engine, is noted for its cutting performance and versatility, offering four mowing methods: collection, side discharge, rear discharge, and mulching. Users have mixed opinions; while some praise its performance on large lawns (up to 3200m²), others express concerns about the durability of its housing compared to competitors like the World GRL530S. Long-term reliability remains uncertain, with some users advocating for a cautious approach to purchasing based on initial experiences. The mower's engine power is highlighted, but some users question the necessity of such a strong engine for typical mowing tasks. Ultimately, the decision to buy may depend on individual needs and preferences regarding comfort and functionality.
