Huawei P9 lite - Flickering ruler at the bottom of the screen
Htomas 3207 5
  • #1 16579583
    Htomas
    Rate: 152
    For some time now, the lower line of the display has been flickering on the phone as in the attached film. This is a bit annoying. The display fell?
    [movie: 19db1db720] https://filmy.elektroda.pl/64_1499708666.mp4 [/ movie: 19db1db720]
  • #2 16579640
    El3ktr0d0wi3c
    Rate: 26
    I'm afraid it's probably a dying display. The phone was not in contact with water?
  • #3 16579668
    Htomas
    Rate: 152
    I don't know. It's not mine. It's under warranty. If it was wet, are these symptoms? And does this model have an element that changes color when wet?
  • #4 16579670
    El3ktr0d0wi3c
    Rate: 26
    The color-changing element is for sure. After flooding, various things can happen to the phone.
  • #5 16579721
    nutergsm
    Help: 1034
    Rate: 1665
    Since it is under warranty, there is no need to combine it and send it back for warranty repair.
  • #6 16873200
    Tom1916
    Have you solved the problem? It is the same for me
